2003 Disco II tranny problem
JimmyG
Member
Fired up the Disco II and both the Manual Mode and Sport Mode lights are flashing together. The owners manual says this indicates an electrical fault with the automatic gearbox. You should seek qualified assistance urgently.
Anyone have experience with this condition or know what it really means or how to fix it?
Thanks. JimG.
LarryK
On the newer DIIs battery will not reset trans faults, also OBD2 only does engine. Find a local shop that has AutoLogic or Rovacom systems. Shops in US can be found on RangeRovers.net this also includes DIIs.
R 2003 Discovery restoration story Rover / Land Rover 11
C FS: 2003 Mercedes Benz CL600 with Extended Warranty Other Cars 0
K TR5/TR250 TR250 Grille for $2003. ???? Triumph 11
O BAD PING STYPE R 2003 NOW 2005 R MOTOR ERROR CODES Jaguar 1
swift6 2003 Bentley Arnage, suspension pics... Other British Cars 2
1 What's the consensus of the XJ8 up to year 2003 Jaguar 4
jackq 2003 Euro??? British Motorbikes 8
C 2002 2003 vandenplas Jaguar 2
J 2003 XJ8 MYSTERY WATER LEAK Jaguar 2
J 2003 XJ8 Soverein seeking input Jaguar 5
J 2003 Caterham Super Seven Roadsport SV Lotus 15
Bret San Diego British Car Day 2003 Photos MG 6
J The reason stated the Esprit will disappear after 2003 is....[look inside to find out Lotus 2
tr7andtvr Shop Time Disco II Transmission Swap? Rover / Land Rover 6
mailbox Disco engine swap Rover / Land Rover 3
boeingpilot Remote Starter for 2001 Disco Rover / Land Rover 1
W Timing Belt Replacement on a disco Rover / Land Rover 0
catfood New Disco launched Other Cars 6
M Tranny Mount Bolts Spridgets 3
M Tranny Mount Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
R Tranny ? Spridgets 3
2 TR2/3/3A Oil leak in tranny Triumph 4
J TR5/TR250 tranny woes Triumph 15
Got_All_4 TR4/4A Interesting Tranny problem Triumph 9
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
F Ribbed case tranny in 948 bugeye Spridgets 2
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
histerical Datsun tranny help please Spridgets 18
histerical Tranny build Spridgets 0
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
GTP1960 TR2/3/3A tr6 Type A OD tranny service Triumph 10
C stupid question on tranny oil Spridgets 9
Got_All_4 General Tech How do i get these out? Tranny cover plugs Triumph 6
BillyB62 Sideshift OD tranny Austin Healey 15
Griz Tranny O/D Austin Healey 2
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
Got_All_4 General TR Identifing the tranny number on my j type Triumph 7
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
Rut 210 tranny Spridgets 10
T TR4/4A Want to buy tr4 tranny for my tr3a Triumph 17
R Od/tranny 100-4 Austin Healey 6
