1275 head gasket
dingleberry3343
I am building a 1275.
Which side is the haed side on the head gasket?
The steel liner on the gasket is solid between the bores on one side and not on the other. Does this go up or down?
Thanks
Tony
Platinum
It ~should~ have the word "FRONT" stamped on it, then you can match up the thing only ONE way.
HTH
Thanks
Tony
Tony, it's odd that it's not marked top and front, most head gaskets are, but all the gaskets as you described I've worked with with the steel liner/fire ring joining between the bores, that side wnet towards the block.
Platinum
Same here. What kind (brand) of gasket IS it? I can't recall ever seein' an unmarked one either. Odd.
Baz
I've had one with no markings, came from one of the usual suspects. Doc, Remember the thread where the gasket didn't have the oil galley hole?
Tony, get a Payen.
Platinum
Ah-HAH!!! Counterfeit!!
Payen, aye!
L 1275 Head Gasket Spridgets 7
jvandyke head gasket 1098 vs 1275 Spridgets 1
6 1275 Head to block dowel pins Spridgets 10
bugedd 1275 Head Question Spridgets 8
B 1275 Head Identification Spridgets 5
Boink Hardened/strong head studs on a 1275 - torque? Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
T Milling a head on a Stock 1275 for compression? Spridgets 13
BugeyeNJ58 Cost to ship 1275 Cylinder Head? Spridgets 9
BugeyeNJ58 Head Torque Questions for 1275 Spridgets 1
F head bolts 1275 motor Spridgets 2
M 1275 Rebuild Question - Head Bolts Spridgets 6
regularman If a 1275 head had a crack in it. Spridgets 25
regularman I need a 1275 head. Spridgets 12
T BMW K100 DOHC FI head on 1275 block Spridgets 7
pakiwi Head Off - 1275 - Recommendations Spridgets 19
T Rough budget +/- for 1275 cylinder head overhaul? Spridgets 10
Gray_Cat Looking for a 1275 Cylinder Head? Spridgets 0
E 1275 Cylinder Head Bypass Nipple Spridgets 4
Bruce_B Bolt torque sequence on 11 bolt cylinder head 1275 Spridgets 7
J 1275 Cyl Head volume question Spridgets 2
drooartz Smog head 1275 question Spridgets 33
cdsmith First time installing a head on a 1275 Spridgets 6
nathandarby67 Head swap for 1275 engine? MG 4
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
