Rough budget +/- for 1275 cylinder head overhaul?
tdskip
Hi guys - I know this will vary by location, fullness of the moon, ambient humidity and levels of caffeine in your system etc... , but what should I budget for a 1275 cylinder head overhaul?
PAUL161
Ask Hap!
Morris
I would say somewhere in the area of $300-$2000. Give or take a few bucks.
Can you give us some more details?
T
tdskip
LOL Morris.
So here is the deal - I'm trying to budget for "smart" things to do before the 1275 goes into the Bugeye. You guys were very helpful with ideas and suggestions on seals and clutch and related items that are easier to do with the engine out already.
That go me thinking about a quick, if there is such a thing, refresh of the head. Her compression is actually decent and consistent, but who can resist tinkering...
I've also seen some rebuild heads for sale for around $300, which seems cheap for combination of a new head and the rebuilding that has been done on it.
Dadandson
Boil, Magnaflux and shot blast, $75.
New Manganese valve guides, valve springs and valve seals, $120
Grinding and polishing supplies, $25
Hours spent reading David Vissard's book and performing the work, 25-30
Results, $Priceless!
This is in the Metro Phoenix area.
Don't forget to put hardend exhaust seats in the head, if you forego this, you'll wish you had did it later, budget about 100 bucks for this alone.
John Moore
Around her a valve job for a 4 cyc goes for $125. Hardened seats are an extra $80-100.
FWIW, I d that kind of work, even though I am ways from you, and in your neck of the woods, my good friend David Anton at APT could take care of you as well.
T
tdskip
Thanks Hap - definitely want to support our community. I'm still itching to get the rims on her that I bought from you!
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
K TR2/3/3A Mystery clunking and banging from rear of car when driving over rough road or bumps? Triumph 14
C Rough-Running 3000 Austin Healey 29
tr6web TR6 TR6 rough running - what can it be? Triumph 17
BierRunner TR6 TR6 Running Rough Triumph 5
T TR2/3/3A rough running after 20 min shutdown Triumph 9
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
N Stuck Needle Valve - Rough Running Austin Healey 15
C Rough Idle - What to check? Austin Healey 12
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
D Rough running BT7 3 carb HELP Austin Healey 13
55modified Wanted Wanted rough BN1/2 hood for cutting up Austin Healey Classifieds 0
B Thoughts...rough running at cruise. Austin Healey 3
M TR2/3/3A Engine rough on acceleration Triumph 19
GTP1960 TR2/3/3A Rough running / a lot of carbon on the plugs Triumph 11
K TR2/3/3A Dead Petronix and rough running..... Triumph 10
I BJ8 is running a bit rough. . . Austin Healey 7
B Pics of my ’63 BJ7 and Questions on Hard Starting and Rough Running Austin Healey 11
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
N Runs Rough Under Load Spridgets 15
Gliderman8 General TR Rough looking '67 Vitesse Triumph 7
JPSmit Rough Bugeye hood Spridgets 0
M Rough Idle MG 15
K Rough patch inside bore of SU? Triumph 2
W Mighty rough..... Spridgets 1
justin_mercier Post-War Other 63 Herald in rough shape, MA craigslist Triumph 2
M Rough Running 99 XJ8 after Overheating Jaguar 42
T TR2/3/3A TR3 Running Rough - Cause[s]? Triumph 8
Robert560 Weird "rough" idle problem after ignition changes. Austin Healey 18
B diamond in the rough? Triumph 6
T Rough clearance checks Spridgets 2
K TR2/3/3A TR3 Running Rough Again? Triumph 7
bighealeysource BN6 runs rough on restart after running great Austin Healey 7
M 87 Series III XJ6 Rough Running Jaguar 16
G Rough running and backfiring MG 30
M TR2/3/3A Another rough running TR3 Triumph 1
T TR2/3/3A TR3 running rough Triumph 6
vping Running rough MG 9
bighealeysource Up-date on engine running rough on my BN6 Austin Healey 1
D XJ8 rides rough Jaguar 5
MGB922 Rough Idle MG 13
A rough running after long idle or long low rpm driv Triumph 1
D GT6 Rough GT6--your thoughts? Triumph 9
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
R TR2/3/3A TR3 Missing [running rough not stolen!] Triumph 4
