BN6_2197
My flasher lamp on the dash board does not work regularily if the flasher is switched on. It only lights once. Now I am searching for the cause. There are two main components in the flasher system, the flasher relay and the flasher unit. I hear a quiet "click" in the flasher relay but now "clack" of the flasher unit. I have continuously changing electric tension at the "L" pin of the flasher unit, between 9 Volt and 2 Volt.
Two questions:
* Is this a hint that the flasher unit is defect?
* What is the meaning of the flasher unit within the flasher system at all?
Thank you very much in advance,
Volker
Two questions:
Volker
