MGB MGB and HIF44 SU Hesitation
jdhorton
Hi All-
77 MGB- Replaced my ZS carb with a Moss SU HIF44 carb. I have serious hesitation on acceleration, but excellent running at higher RPM's. Idle is smooth. Has anyone had a similar experience?
Any help is greatly appreciated. (THANKS!)
I ran an HIF6 from an Austin Marina (similar to the HIF44) for several years on my MGB. I used a BBQ needle...which do you have?
Platinum
Where's Eric when we need him. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
J
jdhorton
Hi-
Thanks for the info. This is a Moss item. Do not know what needle came with it. Anyone familiar with their offering?
Thanks, Jim
Platinum
Another thought: what oil are you using in the damper?
... and check the needle for starters.
J
jdhorton
I'm using Castrol 20W-50 in the damper. 'She' runs well (very) with the choke out partially. I adjusted the idle screw (on the choke linkage)to maintain correct idle speed. Should I be able to read the needle ID by withdrawing the piston with the piston intact, or will I need to remove he needle? (That may be and ""idle"" question, since I will pursue the needle ID whatever is required...) Thanks, Jim~
Dave Russell
Yoda - R.I.P
Is that like a spit as used on an outdoor grill?
Well...it's too large for a Spitfire...and doubt if it would be very useful in a Weber.
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Platinum
Needle needs to be removed from the piston to read the "I.D." BUT!!! You just hinted that the choke plays into this. You MAY find that just enrichening the mixture will sort the problem. Locate the HIF mixture screw (a "shrouded" cross-hatch one, in a bore on the side) and run it in a quarter-turn. Drive the beast and note the changes.
I can't recall if "in" (clockwise) or "out" (counter-clockwise) is the richer... I *think* the "in" is the enrichment. Hopefully a more post-emissions familiar member will pap up and define it more accurately.
J
jdhorton
Many thanks to DrEntropy for the good advice on the enrichment adjustment on the HIF44. While it did take considerably more turns than anticipated, the "in" (clockwise) adjustment does, indeed, result in a richer mixture. The B is running very well and I am still making fine tuning decisions almost daily. Very pleased with the operation and response of the HIF44, and I'm glad that I decided to give it a chance.
If anyone knows of an SU (or other) publication/manual containing (more) complete details of the HIF44, I will greatly appreciate the name of the pub(!). I'm sure that I should learn more about the setup and tuning as soon as possible.
Thanks again for your help DrEntropy :O).
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
AngliaGT ANOTHER TR6,& an MGB Spotted 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
