Identifying a Ring and Pinion
philstr6
Would like to ask for help identifying this ring and pinion from the Austin-Healey group. Can't find any info.
Thanks in advance.
Philstr6
Phil
Healey Nut
Healey Nut
Editor_Reid
Platinum
Is there really a difference; i.e. different tooth counts on the pinion or ring, or both? I've always used 3.5 and 3.54 interchangeably.
I've wondered that myself. When Lempert set out to make a gear set to replicate the 3.54, how did it end up being a 3.55? But that's the way they labeled it, so there must be a reason.
However, whether or not there is a good reason, there's really no difference. I got one of his first batch and it's installed in my BN2. I like the longer legs, but the first thing Steve Pike said when he drove the car was, "Where's the power?" I guess he really noticed the slower acceleration. I don't drive it aggressively and so to me the taller rear end is only an advantage.
... I like the longer legs, but the first thing Steve Pike said when he drove the car was, "Where's the power?" I guess he really noticed the slower acceleration. I don't drive it aggressively and so to me the taller rear end is only an advantage.
I think BN2s originally came with a 4.1:1 rear end, so that would be a bigger change than the 3.9 that was in my BJ8. At any rate, for a highway cruiser like my BJ8 the 3.5whatever is a blessing. With the 3.9, first gear is so low as to be unnecessary most of the time, but with the 3.5 it's about right, and second is better, too (still too small a gap between first and second).
V Help with identifying morris eight Other British Cars 12
T Lotus 7 - help identifying parts Lotus 5
P TR6 identifying switch Triumph 3
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
J MGB Need help identifying these parts MG 6
T Wedge TR7 engine, need help identifying part. Triumph 5
S Identifying 12G940 heads Spridgets 4
JimLaney HELP: Identifying Chasiss and Engines Spridgets 7
Desert Rat Help identifying a hardtop Spridgets 10
P TR2/3/3A Need Help Identifying These Seats Triumph 6
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
T Identifying vintage of a Weber DCOE Spridgets 4
L RE: Requesting help with identifying suspected rear brake adjuster piece? Austin Healey 4
L Request help with identifying this AH 1960 3000 part. Austin Healey 1
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
jfarris TR2/3/3A Identifying a TR4 A Overdrive Triumph 5
AngliaGT Wedge Help Identifying TR7/8 Parts Triumph 8
S help with identifying fiberglass frontend Spridgets 27
J Need help identifying Lucas parts Other British Cars 10
CZ_Dave Help in Identifying this British Ford? Other Cars 11
J help identifying my transmission... Triumph 8
B Please help identifying top bows MG 5
J Identifying Lotus 907 engine castings [Jensen H] Other British Cars 8
S Need help identifying rims Other British Cars 11
angelfj1 TR2/3/3A TR3A help identifying part Triumph 6
angelfj1 TR2/3/3A TR3A - help identifying part Triumph 9
Morris Help identifying carb set... Spridgets 18
T BugEye - identifying rear axles[?] Spridgets 0
C help identifying hard top Spridgets 1
Gliderman8 TR6 Help with identifying my TR6 heads Triumph 3
angelfj1 TR2/3/3A Help identifying part [TR3A] Triumph 5
T Identifying year of production from serial number Spridgets 5
vping Need help Identifying an OD Transmission MG 3
A Help needed - identifying cylinder head castings Austin Healey 0
Monark192 Help identifying Carbs MG 2
vping Help identifying this odd part MG 11
T Need Help Identifying Parts MG 5
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
S New member with a Q about identifying an engine. Other British Cars 0
S Greetings! and help identifying this engine?. Sunbeam (Rootes) 14
Mickey Richaud Help with Identifying this TR Triumph 6
ChrisS MGB Identifying a MGB Transmission MG 1
T Help identifying part Spridgets 16
MGTF1250Dave Help Identifying Distributor Triumph 3
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
sail TR4/4A Piston Ring Question Triumph 6
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
