MGB Starter bolts
Coastalman
Today I am working on installing the starter on my project 66 B. All the bolts that came in the Moss package to put the transmission to the back of the engine are 1/2 inch. I used a 1/2 inch bolt on the upper hole of the starter to mount it to the engine plate and bell housing. The lower bolt goes into a a hole that ends in an enclosed part of the bell housing. The half inch bolt will go into that hole, but will not tighten up. I tried a 9/16 bolt and it will start, but not go very far.
What is the correct bolt to go into that lower mounting for the starter? Could the threads be stripped?
Thanks
Charlie
Mickey Richaud
Hey, Charlie -
The top and bottom bolts are different threads, but both are 3/8" diameter thread. I believe the top is coarse thread, 3/8 X 1 3/4" long; the bottom is fine thread (24 tpi), 3/8 X 1". Remember, if bolts are threaded into aluminum, they are usually coarse-threaded; steel, usually fine. Don't forget the lock washers.
bobhustead
Note that Mickey is talking about diameter of the bolt and Coastalman is arrarently talking about the head size. Bear that in mind as you try new fasteners.
Mickey Richaud
Thanks clarifying that, Bob.
Mickey
C
Coastalman
The right bolt was sourced and installed. Thanks to all for giving me the information I needed. I question myself when all the other bolts work just fine and one does not. Thank you BMC for keeping my life from being trouble free. Among many other things.:smile:
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
W Generator and Starter Long Bolts Spridgets 0
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
B TR2/3/3A Starter catches 50% of the time Triumph 15
