BN2 new wood steering wheel install
Papa Law
Finally got my Healey 100M steering wheel in from Mike Lempert and it looks perfect. Read all I could to find out about the project but everything references the 6 cylinder cars. Can anyone tell me where to look or give me some info on the 1956 Healey BN2. I have a non adjustable wheel and need to know how to get the trafficator off to accomplish the task. The BN2 service manual starts after the trafficator is off so that is no help. One article in Moss Motors had a gentleman do it without removing the wires at the steering box but it was for a later 6 cylinder model. Thanks for any help!
roscoe
What you need to do is disconnect the wire harness from the trafficator where it passes through the steering box and exits through a "gland nut" which is what actually holds the long tube that contains the wires from the switch mechanism in the steering wheel. You can access that section of the harness through the left ffront wheel well(assuming Lh drive). Loosen the gland nut and you should be able to wiggle the trafficator assembly and tube out towards the rear of the car. It is a long tube and once you get the wire harness moving it should slide out easily. The gland nut on the front side of the steering box is what holds the whole thing in place. You might consider taping a strand of string or thin wire to the end you are pulling through so you can use it to pull the wires back through when you are done. Also, it has been a long time since I did that job but I think your steering box oil falls out when you loosen the gland nut (also called an olive nut) so you might want to drain it first.
steveg
For less mess, I like to leave the stator tube in place and the olive tight.
In my case, I've never been able to pull all 4 bullets through the stator tube. I drilled out 2 -4 with a 1/16" drill and pulled the wires out the stator tube. For installation I attached a female bullet connector to a long bailing wire. I put shrinkwrap over wires 2 - 4 and pulled the whole thing forward through the stator. Then resoldered bullets 2 - 4 to their wires.
DerekJ
I would take the opportunity to remove the trafficator altogether. Although it is an interesting piece of antique Bakelite IMHO it doesn't belong in a sports car. It is fiddly to install and use and looks like it belongs in a 1940s family saloon. Move the horn and indicator to the dashboard and fit a nice alloy blanking plate. Another very clean option is to fit a Motolita horn push and just move the indicator to the dashboard.
I recently put a Lempert Wheel in my BN2. I found that the 'Lempert' hub--which is actually made by Mota Lita but modified by Mike--has a slightly longer splined section:
Mike said he hadn't seen--and/or didn't know about--this, and I didn't get quite as much thread on the big nut as I would have liked, but it worked.
A BN2 Chassis Alignment Austin Healey 8
T 100 BN2 Possible Ignition Issue Austin Healey 7
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
H BN7 and BN2 Lengths Austin Healey 3
Gundog61 BN2 Brake Drums Austin Healey 5
bighealeysource BN2 Master Cylinder Austin Healey 91
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
MikeAH100M BN2 Tight Steering Austin Healey 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
Guido36 9k-Mile BN2 at Auction Austin Healey 13
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
Guido36 BN1/BN2 Sidescreens Austin Healey 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
J BN2 Shift Lever Bushing Replacement Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J 100 bn1/bn2 id Austin Healey 26
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
J BN2 shift bushing replacement Austin Healey 5
wangdango BN2 wheel cyclinders/replacement Austin Healey 1
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
P BN2 Walnut Steering Wheel Austin Healey 10
P Healey BN2 Distributor Question Austin Healey 1
Martinld123 Austin Healey BN2 oil leak at base of distributor Austin Healey 7
