Results 1 to 12 of 12
Thread: radiator spigot fix
  1. #1
    Join Date
    Feb 2006
    Location
    Laguna Beach, CA
    Posts
    262
    Chats
    radiator spigot fix
    After 32 years of ownership '65 3000, '67EType and at least the last ten of trying to stop leak from radiator spigot including lapping the valve seat, and buying a new one that also leaked, a small cork bought at Ace hardware jammed into opening got it down to 2 drops an overnight. So finally decided to launch all-out war with plans to seal with solder, expoxy weld stuff etc, ended up with a stainless steel, fine thread, 1/2" dia, 1/2 inch long bolt from Ace hardware (small Ace store did not have but big store 4 mi up PCH did [tried six others home depot, PEP Boys etc.no luck]), also a plumbing dept washer, whitish plastic-like (used before and works fine). NO DROPS either car, no newspaper on garage floor at front, Jay
  2. #2
    Join Date
    Aug 2016
    Location
    Greensburg, PA
    Posts
    80
    Chats
    Re: radiator spigot fix
    So now on to the oil leaks.
  3. #3
    Join Date
    Dec 2010
    Location
    san luis obispo california
    Posts
    1,934
    Chats
    Nice fix! Except,...Now how will you know when the radiator is empty?
    Last edited by elrey; 01-03-2018 at 12:39 AM. Reason: One of my pals has soldered his shut, since the original is pretty and most folks just pop the hose off to drain anyhow.
    A wise man knows he knows not. Lao Tsu
  4. #4
    Quote Originally Posted by elrey View Post
    Nice fix except...Now how ya gonna know when the radiators empty?
    Am I missing something here? Please explain.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  5. #5
    Join Date
    Dec 2010
    Location
    Posts
    1,934
    Chats
    Humor, you know the old joke about how you can tell when your British car has run out of oil? Answer: When it has stopped leaking. Just having some fun. I am fond of the original radiator petcock's look. The stylish heater valve on the engine is my favorite.
  6. #6
    I get it - we need it to leak so we know when it's empty.
    Steve Gerow
    Altadena, CA, USA
  7. #7
    Join Date
    Dec 2010
    Location
    Posts
    1,934
    Chats
  8. #8
    Yoda GregW's Avatar
    Join Date
    Jan 2005
    Location
    Santa Monica, CA
    Posts
    7,495
    Chats
    2
    Quote Originally Posted by steveg View Post
    They tried Lucas warning lights on the dash, but those burned out before the radiator emptied.
  9. #9
    Yoda GregW's Avatar
    Join Date
    Jan 2005
    Location
    Santa Monica, CA
    Posts
    7,495
    Chats
    2
    So Jay, are you saying you replaced the spigot entirely with the bolt?
  10. #10
    Join Date
    Dec 2010
    Location
    Posts
    1,934
    Chats
    Quote Originally Posted by GregW View Post
  11. #11
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,204
    Chats
    --------Keoke
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  12. #12
    Join Date
    Jan 2015
    Location
    Martinez, Ca
    Posts
    191
    Chats
    Just a heads up, but the threads on the petcock/spigot are British Standard Pipe. To be specific, they are 1/4''-19 BSPP. Anyone looking for a drain plug, in stainless, they are available from British Tool and Fasteners. I have also purchased a similar item in brass from Ebay seller "bsanut".
    ​Both items were very good quality.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
