6-cylinder alloy valve cover
vette
Re: 6 cycl alloy valve cover?
All I can tell you is that this one was on my engine when I bought the car almost 20 years ago. So I kept it. It is solid as a rock, seals like a submarine, has no flex and will get shiny if you want it that way. Can't see any reason to use a tin one ever again.
I personally do not consider it an "upgrade". It is just bling. I happen to like the looks of the fluted one.
Hangtown Healey
I have been looking for an old add for mine. Probably marketed by Hollywood Sport Cars.This picture is of the 4 cylinder version.mystery valve cover.jpg
Scot
Or just chrome the original one! Cheers!
Michael Oritt
I have an early (see thumbnail) AL cover on my 100 which has 9 fins versus 10 in Ray's design. I have heard that they were sold by JC Whitney back in the day. In any case I would recommend getting one of Ray's as it will definitely add bling if not speed.
gonzo
Ray's Alloy Finned Valve Cover is my choice - see before and after pics. But I like vette's too! GONZO
red57
I have no idea who made mine but I have two of them - one I bought from Gary Hemphill 20 years ago, the other on ebay.
Patrick67BJ8
This is an aftermarket accessory one offered a long time ago but I don't know who made it either. I have the same one on my Healey. You are missing the breather style oil filter cap.
Michael Oritt
I don't know the origin of the valve cover Red57 pictures but the early finned covers such as the one on my car were flat on top whereas Ray's covers have a rocker to them.
red57
Patrick, I would really like to see a picture of a correct filler cap - the one I have is what came with it when I bought it used. My cap is not a vent/breather but seals with a cork gasket.
Michael, That's interesting because mine has a distinct crown from front to rear which I really like. Isn't that the point of bling, something you like.
To the original questions, I don't think it's really an 'improvement" but I do like them.
Dave
Mine's the same as vette's; bought it through Moss Motors around 1984. Since this picture was taken, I replaced the mounting hdwr w/stainless steel pieces.
EV2239
Mine's off a Vanden Plas 3 litre and the same as the works cars used at the time.
Keoke
I am considering upgrading, anyone have opinions etc?
Any one suggested above that fits your fancy combined with a silicone sealing gasket can eliminate valve cover oil leaks for life.
andrea
The aluminum valve cover solved my problems, happened with 2 steel covers- hole- distortion bad planarity-oil arrived at my windshield and silicone sealing gasket reduced the problems but don't solve it completely- the choice ca be at personal taste or economical - ribbed cover have more dissipation power
My choice (I don't remember if from AH Spare or A Head 4) was for simplicity economy and availability
https://photos.app.goo.gl/2p61qM5sHZcRD7u22
CaptRandy
Red57, I have looks to be same VC as yours, here is photo with the breather cap. Tried to attach but system will not accept my photo
Hangtown Healey
In Southern Cal in the late 70's, an old guy named Walt had the patterns so a few more could be made for Association members. I got one then. They could well have been made by Moon once.
M Alloy cylinder head Austin Healey 5
W Alloy Cylinder Head Or Not MG 13
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 1
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
W Cylinder compression Hillman super minx Other British Cars 15
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
Donald1107 TR2/3/3A low cylinder compression Triumph 12
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
S TR2/3/3A rear wheel cylinder Triumph 1
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
6 Master Cylinder Actuator rods Spridgets 2
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
6 Master Cylinder Install Spridgets 5
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR6 Rear brake wheel cylinder fitment Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
