TR2/3/3A NU and NE wire gauge/amperage rating
mastaphixa
Bronze
Can anyone tell me what the wire gauge and amperage rating of the NU and NE (brown with white tracer and brown with blue tracer) are? They are connected to the A and A1 terminal of the general control unit.
Thanks,
Steve Baker
TR3driver
Great Pumpkin - R.I.P
I believe they are 44 strand, roughly equivalent to 12 AWG and rated at 25.5 amps continuous. But they will carry more for short periods of time as long as the connections are good. I ran for many years with a 65 amp alternator feeding the battery through the original NW and N and never had any problem with the wire overheating.
BTW, brown with white is NW. NU is brown with blue.
M
mastaphixa
Bronze
Randall,
Thanks so much! I want to protect them with a 30 amp fuse so that should work out just fine.
I TR6 Gauge/color wire ? Triumph 9
Darwin Spitfire ignition wire gauge Triumph 2
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K TR2/3/3A Wiring harness "wire gauge" sizes? Triumph 20
C TR2/3/3A Electric Wire gauge size Triumph 2
G What Gauge Wire ? Triumph 5
T TR2/3/3A On TR3A what gauge wire from fuse box to coil? Triumph 17
I Bugeye wiper motor wire gauge? Spridgets 12
M Prpoper wire gauge Triumph 3
Nelson Wire gauge? Spridgets 5
T Coil to distributor wire gauge question Triumph 45
tahoe healey Gauge of fuel pump wire Austin Healey 5
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
KLUTZ Wedge FASD wire question Triumph 1
P TR5/TR250 Wire wheels width Triumph 8
P Wire Wheel Splines Austin Healey 10
KVH General Tech O/D Electrical Wire Burned Triumph 22
D Wire Wheels and Air Leak Austin Healey 16
S TR2/3/3A wire repair Triumph 7
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R General TR Emergency hot wire - because you never know whats next Triumph 2
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
S MGB mystery wire MG 32
RJS General TR Wire Wheel Spline Question Triumph 3
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
steveg TR6 Steering boot clamp wire - why? Triumph 2
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
B TR4/4A Wire wheel question Triumph 10
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
T Location of ground wire for BJ8 Austin Healey 6
C What to do about my wire wheels Restoration & Tools 6
P TR5/TR250 wire wheel question Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
