When did gloves become required for every job?
DavidApp
I have noticed recently that everyone on you tube working on almost anything wear gloves. Mechanics put on gloves before they work on motors, gardeners put on gloves and woodworkers have to get gloved up.
Welding gloves I get as well as gloves if you are handling sheet metal but it seems to have gone to the extreme now.
Or it may be me.
David
I don’t wear gloves unless it’s a safety issue or something that won’t wash of easily.
Latex gloves make it easier, just pull them off and throw them in the trash! A lot easier than scrubbing for half an hour getting the crud off. More friendly shaking hands also. :highly_amused: PJ
Since most automotive fluids are not good for your skin, I wear the nitrile gloves when working on the Healey, or any of the others. Nitrile has rather good chemical resistance.
Many jobs at work require gloves and I have gotten used to using gloves as a result. I now use gloves for many jobs at home. Prevents a lot of minor finger injuries and is much easier to clean up. I think the big difference is that modern stretchy gloves are comfortable, cheep and have better grip than your fingers.
Most times it depends on the job, for me. Nitrile if petrochemicals are involved, particularly on a disassembly. Though I must admit I forget to put them on in a lot of instances, too many years of working without 'em. And the scars to back me up.
I do remember to use them for ~any~ job on the diesel, even raising the hood. Diesela's a dirty girl.
I used to never work with gloves, now for a quick job I wear the nitrile, but for a bigger job, whenever I try to wear the gloves they will inevitably tear at some point. I will put a new one on, but after the third or fourth time I just keep working.
I do wear them when I paint a car with the big guns, and sometimes when I spray paint just to make hand clean up easier.
I wear nitrile also any time I'm working in anything there I know I'm likely to get grease or other fluids on my hands.
Since you brought up this
I usually buy mine from Costco.
I am about out and I am looking for a stronger one.
What brand do most like?
I said Latex in my first post, but actually their Nitril I get off the net, 100 to a box. PJ
I usually get mine at Harour freight - they are cheap and usually do an adequate job. If one breaks, I have several boxes more. They probably are not the strongest our there but for most jobs they have been fine.
It is not that I am opposed to the use of gloves. I do use them when I am dealing with solvents and some very dirty engine work but I feel very clumsy in them.
It just seems their use has escalated to an almost must have.
What brought it to the top for me was watching someone drilling holes with a drill press in fairly short pieces of steel holding the piece in gloved hands. Bad on two fronts.
Hand holding on a drill press is asking for trouble. (I admit I do it sometimes but not with very short pieces)
Gloves around a drill press or lathe are not a good idea but I did start in an era when you wore a neck tie to work and were advised to keep it tucked in your shirt while around moving machines.
David
I wear them most times except when I’m trying to start a screw or a nut. Especially when working under the dash and you can’t see. Without the gloves offers more tactile feel.
For years never wore them. But, shops provide them for protection against the fluids, as a cancer risk. Heavy gloves for metal fabrication, welding ,etc. Nitril for mechanical wotk, easier to clean grease and oil smears off. Years back the hand cleaners had lanolin as a base, now considered a cancer hazard. Orange stuff, some people get sick of the smell. Gloves help U.N.il they tear and dawn/water mixed in a spray bottle works good as a cleaner of dirty hands.
The ones at Harbor Freight come in a medium weight (100/box) or heavy weight (50/box). I mostly use the heavy weight ones for mechanical work. I'll use the medium weight for painting or emptying the RV tanks.
Neither come with worms.
I wear leather gloves for pruning roses.
Did some quick research
They have a mil size on them
8 mil is the thickest I seen in a quick search
