MGA wheels
rondelp
1500, thinking of changing from disc wheels to wire. But need Moss conversion kit ~$1K. Minilite wheels suggested. Nice look.
so ?'s: look vs wire, effect on future value since not stock, found many Minilites for many cars but not MGA; ideas, do they require Moss conversinon kit like wire? ? thx, Ron
Platinum
Grantura_MKI
R
rondelp
Thx to both. Is that Moss conversion kit required; again disc wheels have a wider axle? the kit reduces width for wire. They seem to be more like disc wheels so perhaps no kit?? Ron
billspohn
I would fit Dunlop style solid wheels with a center knock off.
Crazy idea. Those wheels are used only on Twin Cam and Deluxe cars and the wheels alone cost around $3K a set, then you have to get the four wheel disc brakes set up with hubs that they fit on (they are not splined, they are peg drive). You'd be looking at an $8K conversion. IF you could even find the parts to buy.
Much easier to find a pair of splined front hubs from an MGA. You'd also need the entire rear end (the width is different) although you could cheat and use Triumph adaptors to add wires to the rear.
Sarastro
I had a wire-wheel car in my early days, and I hated it. Spent too much of my life tuning those wheels. I've found steel disk wheels on British cars generally too flimsy, and they are often too narrow for modern tires. I put VTOs on my TR4A. They are not a period wheel, but the style is such that it seems appropriate for the car. Spending $1K at Moss for the privilege of having wheels that go out of true when you run over a pebble isn't something I'd like to do.
billspohn
1 - wire wheels are perfectly safe for street driving, but the more spokes the stronger they are. The original 48 spoke wheels aren't up to much. The sweet spot may be the 60 spoke wheels used on some Triumphs, but the best solution are 72 spoke wheels as used on TR6 - the only downside is they they look a little 'busy' with all those spokes.
2 - glad to see that we have given up on Twin Cam wheels. The repica ones have insufficient engagement length on the hub threads and are potentially dangerous. The originals, as I previously pointed out are unaffordable.
3 - consider some nice bolt on alloys. There are number of options. Be aware that having a knock off version means increasing unsprung weight as they use a solid machine adaptor that weighs more than the wire wheels do.
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
B Wheels and Tires Selection Austin Healey 10
F MGB-GT what do these wheels go to MG 1
CARSINC My Spyder-Mite Gets Wheels Spridgets 9
K TR2/3/3A American Racing Slot Wheels Triumph 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
T "Flashpower" Steering Wheels Austin Healey 3
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W For Sale Wheels for sale Austin Healey Classifieds 1
glemon Wanted TR250 Wheels Triumph Classifieds 1
D MGB BWA Alloy Wheels MG 9
T TR2/3/3A minilite wheels Triumph 5
R Bugeye splined wheels Spridgets 0
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
P TR5/TR250 Wire wheels width Triumph 8
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Wire Wheels and Air Leak Austin Healey 16
algot1901 Wheels or Rims Lug Pattern Other British Cars 12
drooartz New wheels and tires for Penny Spridgets 16
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
Y MGB Aftermarket wheels MG 5
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
F For Sale: Minilite Style Knockoff Wheels, 15" x 5.5" Austin Healey Classifieds 2
F TR6 Wheels and tires Triumph 10
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
M TR6 Center cap for wheels Triumph 2
C Replacement wheels Rover / Land Rover 1
B Refinishing Minilite Magnesium wheels Restoration & Tools 0
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Recommendation on wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
DerekJ Original steering wheels Austin Healey 1
B TR2/3/3A Tubes in steel wheels? Triumph 18
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Jim_Gruber Spare Wheel Cap for JBW Wheels Spridgets 1
