jcatnite
Are you saying that you put pure antifreeze in your radiator? If so this isn't the source of your problem but it will be at some point. I wouldn't ever put more than 50% strength antifreeze in the coolant system. Too high of a concentration can't remove heat as well as a proper mixture. Also you could have dislodged a bit of gunk that might be interfering with the water choke. I don't know much about water chokes as I have a manual choke. The article Tony put together about water chokes is pretty good but there is another out there that I like well. It can be found here https://www.paulbunyan.net/~jasko/choke/
JC
JC
Hi Guest!
