i used the same bracket. i just bent another piece of metal, cut to the same width, and put a flange on each end. added it in as an extension.
basically just adding a piece to make the loop bigger. then put it right over the alternator the same way. my bracket looks a little different than yours though. you would have to bend one of your flanges to work. Or take a piece of flat metal and bend your own. just a bigger loop.
a number of other people mounted the coil to the upright brace for the fender that is next to the diz.
