Inspector said there is LOTS of water. We are no more than 300 feet from the Bay of Quinte which is probably about 20 feet lower than the house, so, water table shouldn't be an issue.Thanks J-P - you've got low water level in the well, and probably need to have the well drilled deeper (200ft?)
I don't know what the "little lever on the side of the box" is - but every time the pump runs, it's emptying the water out of the bottom of the well hole.
What did the house inspector say on the water system, when you had the pre-purchase inspection? You may have a legal recourse on the problem.
Tom M.
