Rut
Jim,
I know it's a pita, but you need to drill out those spot welds in the bulkhead stiffener. Whet you cut the top of the stiffener don't go above the plane of the rear deck since the stiffeners are a little shorter than the originals. Once that's been removed you can get a good idea of the bulkhead condition and when you cut it out leave a little extra along the top since it's a lap joint. In the area of the spring box to bulkhead fit go ahead and make that part a little deeper since the spring components are Bugeye and the bulkhead is later Midget. Find a good place to make a weld along the part of the bulkhead that's left on the tunnel side. Also drill out the spot welds where the old bulkhead joins the inside B pillar and sill and mark this angle so you can put it back the same way.
This is mostly drilling, grinding, cutting and wire wheeling...dirty work in prep for welding in new metal. Clean all of this area really well...Jasco makes a good conditioner/prep and then prime with weld thru. I know you're going to neutralize any surface rust inside the bulkhead area, but after you do go back in with a good inner chassis coating to keep it rust free for a long, long time.
Rut
Rut
Hi Guest!
