Jim_Gruber
OK 95% of the PS Floorpan are now out. And here is what I find after I got things apart. Probably a bit worse than I thought and I'm open for suggestions on next steps. I am particularly concerned about rear bulkhead which has been repaired and patched and in particular Spring Box Alignment. DS Floor is new and there is a partial Rear Bulkhead Repair panel that was welded in place. My question is do I continue to rip out the rear bulkhead or try to repair what I've got. The stringer that runs up the rear bulkhead on the PS needs to be replaced. It is paper thin at the bottom around the curve where it meets up with the floor stringer. It's crap but concerned how do I remove that panel. It was put together with big 1/2" at least spot welds that are ugly. I guess I could approach them with the angle grinder and grind sideways to cut off the rear bulkhead stringer.
Floor stringer needs to be replaced as well. Floorboard brace right in front of the seat will need a repair done. I think I can patch in something rather than cut everything out. Rear Bulkhead will need a repair panel at the bottom where it meets up with the floor. The flange you weld to is missing about 4-5" of flange. This side of the floor BTW was covered up with Seam Sealer. PO spent $3,500 in Welding Work in 1982 and got New Outers, Inners on one side, Footwell Panels, A Posts, Rear Quarters, Bonnet repair( done badly, I sold that bonnet with my Parts Car as it needed fender beading), and a new boot was welded in. Evidently a shunt in the rear occurred.
So guys I need opinions on next steps. I have new floor, floor brace , and rear bulkhead brace in hand. Those who have gone down this road before I welcome your opinion. Peter, Rut, Chris Uddels, Gerard, et al, I welcome your advice and next steps. Scary to have done this but after driving 60FROG in San Diego up in the Mountains on some really fun roads last week, I'm ready to dive in and get Bugsy back on the road. Thanks guys.
