All coolant that came out of both the radiator and engine was normal (green and clean) with no discoloration or rust, so whatever came past the wp seal must have been a combination of old grease with just a hint of coolant to give the slime sprayed around the engine compartment that nice, bittersweet taste.
Anyway, everything was straight-forward with the usual struggle to get the radiator out, etc. Once I had the pump off I could detect a definite wobble in the shaft and there is a good amount of congealed grease built up around where it exits the pump body.
Given that this pump lasted only two years I decided to get a rebuilt one from Healey Surgeons--considerably more expensive ($195.00 with a core exchange) than the County pump sold by Moss but if I do not have to do this job again for several years it will be worth the difference.
