TR2/3/3A Vin TS for the car.
S
sp53
Well I am back with this post because the British Heritage would not give up the vin number. They felt it was fraud. They did say there was a more involved way to find out more information on a vehicle, but they did not say I could get this information with only the engine numbers and it cost twice as much. The place sounded like some kind of original British car manufacturing place with far more detailed report, but again not sure if they will look with just an engine number. I heard Mike Ellis on the TR Register Forum has access to the factory documents. Perhaps Mike Ellis would help if I knew him.
It sounds like using the engine number would be a good number to use for a vin and get a blank plate from Moss and stamp it because there would be no other vin with those numbers, maybe. I will check with the state auto license and see what they suggest to do after I make up a vin with the engine number.
A couple of years ago, I took a title in for different tr3 for licensing the people said it would take a while because the car is not in the computer system and they needed to put the car in the system. The problem now is I have no title; maybe they will let me apply for new title because of the newer computer stuff . Not sure how to take advantage of the car not being in the computer system for many years. Perhaps I could say I lost the title and use the engine number and see where that goes. I prefer to be honest, but I see no other way to get my new rust bucket titled. I would like to have the original vin, but probably not doable, but like said it should be something like TS378xx. I will try the vintage triumph register, I used to get their magazine
steve
Jim_Stevens
NCDMV did indeed accept the paperwork I had, so all is now well. I did need both the Ellis build sheet to get the Comm number from the Engine number... BMH wouldnt do that.
Jim_Stevens
Hi Jim what is the Ellis build sheet?
steve
Mike Ellis in the UK TR Register forum. For a few bucks he gets you data from the original factory records, such as engine to Comm number matching that BMH won’t do.
Jim_Stevens
Replaced the ash that is (my other hobby is woodworking)
TomMull
Charley, I did one side on mine and would be interested in your upgrade. Perhaps I'll do the other side some day.
Tom
charleyf
The upgrade I speak of has to do with the tonneau cover studs located on the side of the doors. I placed a small metal plate below each stud. You would need to remove a small amount of wood and then attach the metal plates with small screws. Then when you mount the studs you drill a hole using the hole in the door as your guide. This allows you to screw the stud into metal instead of wood.
This could work to "repair "an existing set of wood inserts.
Charley
Jim_Stevens
steve
Use the vtr.org trace carts link above (that’s the Mike Ellis link I believe) with the engine number. The paper you’ll get back will have the comm number, with which you can send off to bmht. Then you’ll have two correlating certificates to go to the dmv with.
S
sp53
Hi Jim and thanks for helping. I went to the VTR.org but could not find the correct link. If you have time, can you provide the link again? I could not find the correct link.
Thanks Steve
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
R Correlation between VIN and car color? Austin Healey 3
Atrus Car [Vin/Engine/Body] Number help... Spridgets 14
H MGC MGC Car Number [VIN] frustrations MG 7
R TR6 Triumph vin tag information Triumph 7
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T VIN Number Austin Healey 2
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Year and Vin number Spridgets 5
B VIN confusion Spridgets 6
G TR4/4A Vin # for TR4A Triumph 3
K MGA 1960 MGA Vin MG 3
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
JPSmit Midget VIN question Spridgets 1
Bob Claffie Vin/SN Spridgets 4
H Help decoding Sprite’s VIN please Austin Healey 6
Patrick67BJ8 Early 3000 vs BJ8 vin Austin Healey 3
D Wanted How to locate my father's past Austin Healey1963 3000 Mark III using its Vin # Austin Healey Classifieds 5
69MGC MGC VIN Verification in California MG 4
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
B TR6 Title with correct VIN Triumph 8
Bantamfan midget vin Spridgets 4
S Austin Healey 3000 BT7 1960 VIN chassis STAMP location Austin Healey 9
Marvin Gruber BT7 vin plates Austin Healey 4
M TR2/3/3A 2nd commission [vin] number??? Help. Triumph 12
A Vin number question Austin Healey 14
Steve P. Need Bugeye vin tag & title Spridgets 15
pbraun Door pillar number used as VIN on title. What to do? Spridgets 11
pbraun Help with vin decoding Spridgets 18
D VIN Plate stamping Spridgets 15
bugedd VIN Question Spridgets 19
F TR2/3/3A vin # Triumph 6
B BN7 with BT7 VIN on eBay Austin Healey 11
madhouse 1958 100-6 VIN check [BT7 vs BN4] Austin Healey 7
M 1960 AH 3000, VIN help ? Austin Healey 4
M VIN Number Curiousity - 1960 MKI Austin Healey 1
Jim_Gruber VIN where else to look for #'s on a BE Spridgets 6
C What should the VIN plate look like for a BN1? Austin Healey 1
Jim_Gruber VIN number alternate locations - Somewhere by front suspension????? Spridgets 20
Rut Vin number Spridgets 3
bugedd VIN tag wanted Spridgets 20
R BN7/BN8 VIN search Austin Healey 9
R Healey VIN numbers Austin Healey 2
CJD E in VIN Triumph 10
PAUL161 MGB MGB vin numbers verses years. MG 6
J New stamping for the vin plate Triumph 10
rovernut TR4/4A TR4A IRS VIN differences Triumph 9
T VIN on a mis-identified Sprite Spridgets 4
Brinkerhoff MGB VIN dating on 67 MGB MG 8
