Hap Waldrop
hondo402000 said:anybody thought about the rings not seated yet
Hondo
The plugs would be wet with oil.
Hondo
It means that the carburetors likely are not quite working together. It could be as simple as different oil levels or even different weights of oils in the two dampers, or some accumulated varnish/gunk is slowing the front piston. Worth a quick clean to find out, and that could still have a bit of effect on 1 & 2 cylinders.LexTR3 said:One small thing I noticed. The piston in the back carb falls freely and stops with a loud click; the piston in the front carb falls a little slower and stops with more of a clunk than a click. Doe that mean anything significant?
My thought exactly. Front carb was closed off and not admitting enough fuel/air. #2 is both closer to the crossover tube (which is fairly small), and draws before #1, so it was still getting enough to run well enough. But #1 was pulling so much vacuum that it could not burn completely, leaving the film of soot at idle. Then when the throttle was opened, the soot burned off and it ran fine.Andrew Mace said:Perhaps because there's that balance tube on the manifold (isn't there? I'm working from feeble memory and it's late at night) that -- for the #2 cylinder -- would help negate some of the imbalance between the two carbs? #1, being further away, wouldn't benefit so much.
Andrew Mace said:It could be as simple as different oil levels or even different weights of oils in the two dampers, or some accumulated varnish/gunk is slowing the front piston. Worth a quick clean to find out, and that could still have a bit of effect on 1 & 2 cylinders.
Er, no, all you know is that there was soot when you looked. It might have burned off on the highway, and been replaced when (nearly) idling as you pulled back into your driveway.LexTR3 said:it didn't work the first time.
LexTR3 said:But, first, I have to take the domes off. How is that done without doing damage to anything else? Specifically, I know there is a needle somewhere inside there and I don't want to damage it in any way.
LexTR3 said:Also... dumb question ... do I take the oil out before doing this, or can I pour it out when I get the domes off?
LexTR3 said:I should be able to do that. While I have access to the needle, is there some adjusting to be done with it, or do I return it exactly to the same height?
LexTR3 said:And another question. What if the needles don't match -- front and back? I recall that about 6 months ago the mechanic said something about the carbs being too rich, or something like that, and changed one or both needles. I had no idea what he was doing. If the needles are not the same, and the pistons have been switched, do I leave the needles with the pistons or do I make sure that the rear needle remains in the rear piston, and vice versa.
The plot thickens....
LexTR3 said:And what determines the hight of the needles?
