Healey Nut
No points or condenser. I have a Lumenition kit on order, but won’t get that until I go to the UK in September.Are you using Pertronix?
Hi Guest!
Yes I do ……somewhereDo you have a dwell meter?
I'm jealous that you are at the obligatory debugging stage.... IMHO an unavoidable stage in all nut/bolt rebuilds. I hope to be at this time next year!The fix for the running issue was a carburation problem , it’s solved now , car runs well but has a gearbox issue which means I think the gearbox is coming out over the winter . If you’re cruising at say 60mph and have your hand resting on the gearshift . When you take your foot off the gas you can feel the rear axle unwind as the speed drops and if you don’t hold down slightly on the shifter it kicks out of gear .
I only did a visual on the gearbox when I restored the car it all looked good inside . Now I’m thinking the interlocks for the gears are either worn out or the interlock balls are not in place .
It sounds fine you just have to keep a hand on the gearshift with gentle pressure when you decelerate .
Winter job for me .
Winter job for me .
