TR2/3/3A Transmission Removal
jfarris
I think the answer to this question is obvious, but I'll ask anyway.
I am about to remove the TR4 A OD transmission from my 56 TR3. I've read the procedure from all the usual sources. Once the transmission is out, I need to move the car across the garage on a set of "skates" for storage until I get the replacement transmission in a couple of weeks. I am assuming that I still need to support the rear of the engine versus let it hang on the motor mounts while moving the car. I plan to build a cradle that will sit upon a small furniture dolly so that everything will roll together. What am I missing? Who else has done this successfully - how did you do it?
OK - second question: with the drive shaft unbolted from the tranny, it will only move backwards on the splines about 2.5". Is this enough for the tranny to clear when I pull it backwards?
Thanks, in advance, for any help!
tdskip
Hi Jim. Good idea to support the engine but I've r&r transmissions without doing that for short time periods without issues, if she is going to sit then by all means.
If the driveshaft is out of the way why can't you pull it up and out?
Brinkerhoff
I'd be blocking the engine under the pan , until you can fab a cradle for it. You don't want to do any secondary damage by letting it hang. I think the driveshaft needs to be removed.
JerryVV
You might have difficulty getting it all to move together. Here is another idea. Place a block of wood behind the head and gently lower the engine against the firewall. Might take a 2 x 4 about 6 inches long.
mallard
No problem with the drive shaft, just disconnect from the trans and push it back. It's easier to reinstall the trans if you remove the transmission mount. I just did this because the new rear oil gallery plug was leaking and driving me nuts.
jfarris
jfarris
Thanks for the ideas and hints, I like the 2X4 idea. I remembered the tranny input splines and tip being farther into the clutch and pilot bearing than the 2.5" that I have in front of the drive shaft. I didn't want to get the thing started out and have to stop and remove the DS. I'll give it a try in the next couple of days.
Thanks!
GTP1960
Jim,
Just curious, (if you don't mind):
what type is the replacement transmission?
and what's the story on the old 4A OD?
good luck with the project; I would like to hear how it turns out.
Guy
jfarris
jfarris
Guy,
I am replacing a TR4 A OD with another just like it. I'm getting a freshly rebuilt unit from Brad Orndorff in Orange Beach FL.
The old one became intermittent. After checking the electrics, cleaning the bottom screen, and checking the valve, I decided it must be the pump not working properly. I had no way of checking the pressure. It needed second and third gear synchros anyway, so I decided to replace it with a rebuilt unit. I haven't taken the old one out yet, but trade for the new one on the 19th.
I'll let everyone know how the swap goes, especially the 2X4 brace idea. plus, I need to post some pictures and formally introduce myself at some point.
Jim,
when I put that trans in I used floor jack to hold engine up. I have done the 2x4 trick in the past when I needed to move a car around without a trans. DS will move back plenty to remove trans. Suggest you have heavy cardboard on floorboard to help slide trans out and in. The o/d trans is a lot heavier than std trans so have some help. I did it by myself but not again.
marv
mallard
Jim don't know if you've dealt with Brad in the past, I had two O/D trans rebuilt buy him with great results. No-way connected with him but I like to give a good recommendation when it's warranted.
Keith
sp53
The exhaust will hold the engine some and usually needs to be undone to get the angle correct on re-installation. I would not recommend having the exhaust hold the motor, but it will stiffen the engine drop. I have never done what you are planning, but if I did, I would try a piece of high density plywood( that is the expensive stuff with more ply’s and less gaps/ air pockets in the material)l, and then cut that to fit between the frame shelves that lip on the bottom of the frame. In theory it looks like if the engine were lifted up a little the plywood could slide in and fit up against the flywheel and rear seal area to hold the motor, and for insurance I would put that piece mentioned earlier at the battery box.
Talked to Brad this morning. Sent him two shifter covers. He has build a couple of over drives for me as well. We have been trading parts for over 15 years, no problems.
marv
jfarris
jfarris
Everything is unbolted and ready for my friend to help wiggle the tranny out tomorrow morning (Tuesday 12/16). I've read that it is easier to get out the passenger's side - the hand brake handle is still there, does it need to be removed? Is it really easier out that side? I took the four bolts out of the rear crossmember, then also removed the two big ones bolting the tranny to the crossmember. I thought it might help to be able to separate those pieces as the tranny came out. Your thoughts?
Looks like my son will be here to help put it back in (his mystery Christmas present to me :cool:).
Thanks for the help!
mallard
I would remove the handbrake and take it out the pass side, otherwise you have to deal with the steering wheel. Putting it back in from the pass side is also easier because the clutch lever could get hung up on the lip on the floor board.
sail
This worked well for me with a hole for the drain plug:
jfarris
jfarris
Thanks guys. Richard, that looks like some of the precision tools I've engineered and built in the past!
Jim,
i didn't remove handbrake but that won't hurt to do. As I mentioned eariler, I used cardboard on each side floorboard to let the trans side around on it and then drag it out on it.
Marv
titanic
A piece of plywood cut to fit the floor pan saves wear&tear on the floor. Also, removing the steering wheel reduces the contortions of working in that area.
Berry
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
R TR6 Transmission Removal Anything Special To Know Triumph 9
C removal of transmission cover from 1959 100-6 Austin Healey 16
nevets Transmission tunnel removal Austin Healey 4
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
Kleykamp Transmission/engine mount removal Triumph 4
O TR2/3/3A TR3 Transmission Removal Triumph 2
TimK Transmission Removal/Replacement Austin Healey 3
M Transmission tunnel removal Triumph 14
R 1996 Jaguar XJS transmission cooling line removal Jaguar 0
L 3000 Transmission Removal, alone or with engine? Austin Healey 16
Jayrz Transmission removal Spridgets 4
T Transmission removal Quickie Triumph 23
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
G TR6 [TR6] removal of front transmission seal Triumph 5
Sprocket BJ-7 Transmission Tunnel Removal Austin Healey 5
Morris Transmission removal Spridgets 22
Slider748 TR6 TR6 transmission removal problem Triumph 12
703MGB Transmission removal question MG 2
W Transmission Removal? Austin Healey 19
CharlieCarpenter Need some guidance on transmission removal Austin Healey 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
