TR6 TR6 rear pinion seal
edkap2002
edkap2002
Is it possible to replace differential pinion seal without removing the differential from the frame entirely? thanks
bobhustead
I have no tr6 experience, but I have removed many by taking the flange off (be sure to mark the parts and count turns for reassembly) and sticking a stout screw driver between the pinion and seal and then under one side of the seal to pry out the old seal.
Bob
Geo Hahn
This is what I used to pulled the seal on a TR4, TR3A and a Big Healey...
Don't forget to drain the diff first. Or don't... and it will be self-draining in that case.
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
R For Sale TR6 REAR AXLE HUBS Triumph Classifieds 0
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
mctriumph For sale rear wings Tr6 Triumph Classifieds 3
mctriumph Have a pair of tr6 rear wings Triumph Classifieds 0
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
T TR6 TR6 Rear Bumper Bar Triumph 1
Got_All_4 TR6 Rear Bumper removal 1970 TR6 Triumph 3
T Wanted TR6 rear trailing arms Triumph Classifieds 1
M TR6 TR6 rear bumper Triumph 0
cmacmillan TR6 Rear bumper removal - TR6 Triumph 10
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
T TR6 TR6 aftermarket rear shocks Triumph 35
W TR6 tr6 rear hubs Triumph 3
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
D TR6 76 TR6 Rear Brake Installation Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
D TR6 76 TR6 Rear Right Brake Line Triumph 8
J TR6 rebuilding tr6 rear hubs Triumph 13
T TR6 Passenger side TR6 rear clunk? Triumph 9
W TR6 broken bleeder on rear brakes tr6 Triumph 12
S TR6 tr6 rear shock part number ??? Triumph 5
Coyote1 TR6 TR6 Rear Springs ? Triumph 11
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
O TR6 TR6 Rear Valance ID Triumph 1
TR6oldtimer TR6 TR6 windscreen and rear flat black Triumph 4
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
B TR6 TR6 rear axle oil change Triumph 21
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
glemon TR6 TR250 TR6 Rear Springs Triumph 13
S TR6 Rear suspension TR6 Triumph 8
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
hondo402000 TR6 TR6 Rear Paint, Satin Black Triumph 8
hondo402000 TR6 TR6 rear body Black paint help Triumph 9
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
T TR6 TR6 rear sway bar question Triumph 6
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
T TR6 Is this a TR6 rear sway bar? Triumph 10
B TR6 Removal and Replacement of TR6 rear deck Triumph 3
T TR6 tr6 rear noise Triumph 8
I TR6 Rear brake drum temperature TR6 Triumph 13
I TR6 Rear wheel bearing help TR6 Triumph 6
I TR6 TR6 rear axle u-joint removal help Triumph 14
I TR6 What type of oil for TR6 rear shocks? Triumph 2
