TR6 TR6 dash support in a TR4?
JimTR4
Hi,
Does anyone know if a dash support from a TR6 will fit a TR4?
Looking at schematics in Moss Motors etc, looks like a U shaped bracket ("filler bracket") may be required and possibly I could fabricate that.
Any thoughts?
Thanks,
Jim
DanB
TR6 dash support (with the radio hole it, heater controls, etc) fits TR4A. I have one in mine, because I didn't want to cut a big ole hole in my original to put a modern radio into, so I got one from a TR6. TR4 might be different, I don't know for sure.
Dan B.
JimTR4
JimTR4
Thanks for the input guys. And it is a 4, not a 4A.
Dan - how did you connect the dash support to the dash itself?
The 4/4A has that radio fascia/bracket that has a right-angled lip on it so you can bolt that directly to the underside of the metal dash.
The 6 support has its mounting holes in the vertical face at the top of the support and therefore requires (I think from looking at Moss Motors schematics...) another slimmer, U-shaped channel/bracket which the support bolts into and it in turn bolts to the underside of the metal dash...I think!
Does that make sense and did you have to fit the channel/bracket piece? Moss and TRF ("dash filler bracket") say it’s no longer available from there but I’m thinking I may be able to make one.
Anyway, can you let me know?
Many thanks.
Jim.
glemon
I have one of each, I will try to take a look at the attachment points later tonight, but don't have access two 4 and a 6 to compare dashes.
glemon
The good news, the "feet" that straddle the tunnel and attach to the floor are in the exact same location.
the top part on TR4 dash support does not go up as high,as you stated they attach differently at the top, so some adjustment or fabrication of parts will be needed
DanB
Then there must be some kind of bracket for the TR6 that was not on the support I used. It attaches exactly the same, top and bottom, as the TR4A bracket. Bolts go through from the front on top.
JerryVV
I need to look at my Spare Parts Manual to be certain but I believe there is an L shaped bracket that is attached to the metal dash panel that the dash support then attaches to on a 4A. I'll look tonight when I get home.
DanB
I see what you are talking about Jerry. On the TR6 it is a similar bracket, although U shaped instead of just L. So, the TR6 and TR4A supports ARE interchangeable.
Also in Jerry's link we can see that the TR4 support is a little different.
JimTR4
JimTR4
Thanks for all this guys.
So, the u-shaped TR6 bracket and the L-shaped 4A bracket don't seem to be available anywhere.
I'm thinking I can probably make something from a piece of ally L or channel.
Apart from the obvious of making sure the holes line up! can anyone see any problems in doing that?
glemon - Does the overall height of the 6 support seem the same as total height of the 4/4A support + radio fascia/bracket piece?
Again, many thanks.
Jim
glemon
I am afraid I don't know, I have the TR4 dash support, which is shorter than the 4a-6 item, but not the accompanying pieces that go with it. I would think the 4 dash structure would be the same as the later cars, so they should matc up pretty well, but don't have a TR4, just some old bits of one, so can't say for sure.
glemon
As to the first question, yes, it looks like a matter of finding an appropriate piece of metal, cutting and drilling some holes, but would be easier to assess with all the necessary parts present.
JerryVV
Call Scott Harper at team triumph in Warren Ohio 330-392-7176. Call after 11 AM. He may have that piece. Ask him to look at the Moss picture as a reference.
Good guy with lots of stuff.
Geo Hahn
Can't answer any of the questions but am left wondering -- why would someone want to do this?
Is it to get that extension for the shifter?
Doesn't the 4A/6 take a different shift lever than the 4 and is this part also required to use the later dash support?
JerryVV
4 4A and 6 all have the same lever so the support should work fine but like you I wonder why someone would want to do this.
JimTR4
JimTR4
So Scott at Team Triumph knew what I was talking about and has one he's mailing to me. Thanks for the contact.
As to why I want to do this, see DanB's message above.
Thanks all.
Jim
Geo Hahn
JerryVV said:
4 4A and 6 all have the same lever...
Moss lists different levers for the 4 & 4A though I have no idea if this is correct or what the differences might be:
848-230 and 848-240.
I can see the reluctance to punch a radio hole in original part, but on a TR4 this is just the bracket that connects the support and the dash -- which is available:
TR4 Dash Bracket
Seems like it would be simpler and possibly cheaper to just get that replacement piece and make a radio hole in it.
DanB
You can also use the dogbone pieces (or whatever you call them) from the TR6 to mount speakers on either side of the radio. That is another reason to do it.
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
V TR6 TR6 Center Dash Support Triumph 16
G TR6 Dash support options for TR6 Triumph 8
C TR6 TR6 Dash Support Triumph 5
F TR6 Looking for TR6 metal dash support Triumph 4
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Thickness of original TR6 dash Triumph 2
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
rjc157 For Sale 74 tr6 dash Triumph Classifieds 2
S TR6 TR6 Dash refinish: a nice surprise Triumph 4
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
J TR6 TR6 Dash knobs Triumph 2
G TR6 TR6 dash and windshield frame removal Triumph 13
Tr4dude TR6 Tr6 resto dash Latest Triumph 3
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
S TR6 TR6 Dash Triumph 18
Brosky TR6 Free dash panel, late TR6 Triumph 4
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
G TR6 TR6 dash lights not bright enough Triumph 22
mrv8q TR6 In the dash, '74 TR6 Triumph 2
I TR6 Veneer sanding, TR6 dash Triumph 3
M TR6 TR6 dash Triumph 13
hondo402000 TR6 Veneering a TR6 dash Triumph 15
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
I TR6 TR6 dash help Triumph 8
I TR6 TR6 Dash help Triumph 7
I TR6 Reveneering TR6 Dash Triumph 3
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
B TR6 Installing a new dash in TR6 Triumph 38
2wrench TR6 How do I remove the rheostat from dash of TR6? Triumph 23
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
roofman TR6 72 TR6 dash lite reostat question Triumph 10
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
I TR6 TR6 dash refinishing Triumph 7
J TR6 TR6 DASH HELP? Triumph 6
G TR6 tr6 - really dumb dash question Triumph 4
nathandarby67 TR6 TR6 Dash on ebay Triumph 0
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
