TR4/4A TR4A radiator install into a early TR4 ???
Jerry
Has anyone done this? The later radiator is wider than the frame rails but it looks like it would fit in front of the rails.
Thanks
Jerry
karls59tr
Bronze
Thanks
Jerry
I was under the impression that the Tr3,4and 4A used the same rad, only difference being the the long neck on the 3. I cant see why a 4A rad wouldn't work in a 4.
MDCanaday
Early tr4's HAD the tr3 radiator with the long neck but lacked the hole sometimes for the crank.Later the neck got shorter and by the 64 the neck was gone. Just make sure that when you are doing this job that you uprate the fan.My favorite is the tr7 13 blade.Just cut the old paddles off and trim the hub to fit the 7 part, drill and use.
Md
HerronScott
Karl,
The TR4A radiator is different and wider as Jerry indicates with wider lower mounts and different upper mounts.
The TR4 had at least 2 radiators (although the SPC lists 3 part numbers). The early one had the extension like the TR3 (up to CT9552) while the later one did not.
Scott
J
Jerry
If anyone has used the later radiator, I am trying to see how they fit it into the car. Why would you use the later one? because it has more surface area for cooling.
Jerry
TR4nut
Jerry- My impression was it would not fit, I think the frame rails on a 4 are narrower than a 4A since the 4 basically started with a modified 3 frame so the inner rails are TR3 dimensioned. On the 4A I don't think that is the case, I expect you'd have about 3" more clearance.
J
Jerry
Well, we may have a brand new radiator that you can get with free shipping then. I have a feeling it just is not going to be worth it to fit. We did want the extra cooling from the larger size but maybe that won't work. Some more measuring on Friday. Jerry
HerronScott
Jerry,
Let us know what you find! If you do find a way to mount it (forward you were saying?), you'll need so custom radiator hoses right? If you do mount it in front of the rails won't that move it beyond the radiator shield as well?
Scott
J
Jerry
My friend decided he wanted the larger radiator. His car overheated with the TR3 type. So we trimmed the inner frame rails and then welded back in plates for strength. The view fromt he front looks the same as before, if you did not know it came with the other radiator, you could not tell. There is plenty of frame up there at the front end. This way the radiator fits and needs no longer hoses or adjustments to the fan. We are looking for a better fan than stock, any ideas?
Jerry
TR4nut
Sounds like a very clever and tidy solution. For fan, the yellow 8 blade TR6 fan with a shorter TR3 fan extension works well, thats what I have. They went out of stock about a year ago but I thought someone was back making them again. Ebay has them quite frequently.
HerronScott
Jerry,
Have any pictures?
Scott
TR4eh
Several parts suppliers list a blue plastic 8 blade fan now, it's probably the same part other than the color.
J
Jerry
Could you point me in one of those manufacturers direction? I have looked at VB, MOSS, BPN, and TRF and don't see one.
jerry
TR4nut
Rimmers looks a little cheaper than VB: https://www.rimmerbros.co.uk/Item--i-GRID006544 - still unfortunately much pricier than they used to be. If you have the older square style 4 blade metal fan I would recommend doing something else - those have been known to lose blades over time. And they don't pull worth a darn either.
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Zimmycobra For Sale Original 1966 TR4A Radiator Triumph Classifieds 0
T TR4/4A TR4a top radiator hose question Triumph 10
T TR4/4A Correct front radiator tray for TR4a sway bar? Triumph 6
T TR4/4A TR4A radiator duct options Triumph 8
Stinger TR4/4A TR4A Radiator Duct Question Triumph 7
S TR4/4A TR4A Radiator Triumph 9
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
