Having major problems with my wiring - my starter motor goes on when I hook up battery even though I disconnected starter switch and the key is in the off position. ??? Where should I start?
Click Reply, then enter your text. At the top of the text window is a row of icons. Click the small rectangle to the left of the smiley face. That'll open a small window where you can upload your photo.I did buy a new Solenoid - from Moss Motors - not sure about the small red wire and white wire - which contact to attached to on Solenoid- how do I attached a photo of Solenoid to show?
Did buy a new Solenoid & starter button -did not solve problem- when I turn key on and push starter button - starter motor is activated but stays on constantly. ?The starter will turn without ignition on; the starter can be turned just by pushing the button on the solenoid.
So I'm thinking your starter solenoid is "frozen" on and probably needs replacing if it's an original.
Hope this helps!
Tom M.
