Yes it sounds like you need to get the fuel and choke corrected. If you do not have a good way to clean plugs like a bead blaster, I would get 3 sets of plugs and inspect the old plugs for carbon deposits and fuel fouling and change them out and clean them as needed. Until you can get some engine running time and driving time, the engine adjustment will not be fine-tuned. You should be able to keep the idle high and go around the block or something while you get close to the proper adjustments of fuel mixture, idle, timing, dwell and do not forget to cold set the lifters. I set them at 10.00 cold
