TR3driver
Great Pumpkin - R.I.P
The spark temperature remains the same: ridiculously hot. The wider gap just makes a longer spark. It does help reduce emissions, particularly when the mixture is too lean. But IMO you won't see any improvement in mileage or power.The wider plug gap will force the coil to produce a hotter spark. Most modern coils can handle that. Back in the day, the stock Lucas coil probably couldn't. Keep in mind the HEI GM ignition systems of the 70s and 80s. High energy ignition, .080 plug gaps. Hotter spark, more complete ignition, lower emissions, etc.
And you will see an increase in problems with other components like rotor, cap, and wires (which GM also upgraded for their HEI).
