It can take a few minutes to get there, but you should see oil oozing from the holes in all of the rocker arms. While I wouldn't call it common, it does happen that the passages get clogged up with sludge and deposits, so I try to check it every few years (or on an engine I'm not familiar with).
After finding no flow at all, even with the plug in the head removed; and no evidence of blockage, I assumed the rear cam bearing insert was the problem. Actually went as far as spinning the engine with the starter (with the liners suitably clamped in place, of course) to see if any oil would come up the hole. I got no oil before drilling, and plenty afterwards, so whatever the issue was, the drilling fixed it.
The external oil feed gets oil right from the main oil gallery on the side of the block, so it won't starve any one bearing. But it puts a huge amount of oil into the rocker shaft, which of course means all the other bearings are getting less oil. It literally painted the underside of the hood!
And I could not manage to control all the oil in the top end; the intake guides were rather badly worn from lack of oil and with the external feed they were sucking so much oil that I literally got a warning from the California Air Resources Board for excess smoke! I even drilled the rocker pedestal and installed a 1/16" restrictor, but there was still way too much oil up top.
About the same time as the CARB warning, I installed oil seals on the intake guides; which worked OK until one of them got dislodged somehow and allowed just one cylinder to continue sucking oil. That led to more unpleasantness:
The rocker balls only get 'splash' lubrication, there is no passage leading to them. Seems to be plenty of splash, though, as long as oil is reaching the holes in the rockers. At higher rpm, the oil gets slung off the rocker tips and just goes everywhere inside the cover.
