Yes, the body is on the frame. I guess I'm a little OCD, but inconsistent gaps bug me. The problem wasn't really the size of the gaps, so much as the inconsistency. And once you commit to it...it's hard to stop!?!
Here is the gap as it was after I adjusted the door and front "wing" as closely as possible. To get to this point I had to bend the hinges (actually un-bend them from what the PO had bent), and got the rear door gap right on 3/32", and the lower gap to a consistent 1/8". The photo doesn't show that well, but the front gap varies from 1/16 to 1/4".
Here is a close up of the fender to door gap at the top. It was touching...but if I moved the fender forward, the gap lower on the door was over 1/4". I chose to grind the fender to match the tub and save some welding.
After a little grinding on the back of the door, the rear gap was a consistent 3/32"
Here is the first step, welding about 3/16" of bead along the entire front edge of the door. I started using MIG, as I thought the lower heat would prevent any panel warpage. No such luck, though. Once I saw the panel was going to warp anyway, I switched to Oxy-acetalyne. I am more comfortable controlling the gas weld on thin stock like the door edge. Plus...I hate scraping the spatter from the MIG.
The last step was about 2 days of hammer and dolly work, grinding, and refitting the door at least 2 dozen times. Here is the final result. Once again, the photo does not really show it, but the gap all around and over the front of the door is a consistent 3/32".
The inside, engine bay, and bottom of the tub are already painted. All of the mods were done to the door itself, though, so the paint is still untouched. The tolerance on the hammer/dolly work is within 1/64", so a good coat of primer will level the door completely. I will hit it with a smear of glaze anyway before priming. Here is the side of the car:
Well, on the the other side now!?!
John
