TR Frame Data Plates?
JohnnyMead
There's a data plate about the size of one of the brass body number plates welded on the top of the front-most cross-piece of my TR3A. It looks like it has at least one number (a "3") stamped on it. Can anyone shed light on this?
Thanks,
John
mallard
For all my muscle car friends I show them mine (Z28). No idea what it means.
JohnB
Bronze
John,
The plates were attatched by the frame manufacturer.
My TR2 from '54 has "Z 20" on it. I assume "Z" stood for Triumph frames. I do know every time they improved the frame in any way, it was given a new number.
Not sure if any one has ever correlated the numbers with the changes. It would be very interesting to see the progression of improvements over the years on these frames, as they relate to the numbers.
Don Elliott
My frame is "Z28". My 1958 TR3A was "born" on Feb. 14th, 1958. The Comm. No. is TS 27489 LO. This is how it looked in 1988 during my restoration. Originally, the frame was Primrose Yellow. I've driven 102,000 miles since 1990.
Don Elliott, Original Owner.
JohnB
Bronze
It would appear the "Z" series applies to the TR2 and TR3 series only?
What other letters are out there and for which TR series?
bgbassplyr
My early TR4 (CT5589) has a large B and a smaller 8.
vivdownunder
That frame sequence number was applied by the manufacturer, Sankey, for each update such as strengthening the rear lever arm shocker brackets, various minor changes to fuel line fixings, brake mounts, and bracketry including when the split steering was fitted.
There was another mark on the front crossmember to give dead centre for frame straightening.
Regards,
Viv.
JohnB
Bronze
So the TR2 and 3 were a Z plate.
The TR4 was a B plate.
And the TR4a had a C and D plates, and they all changes nos. with improvements.
Any other examples out there? Would be interesting to see a full listing of plate letters and their cars.
TexasKnucklehead
My car seems to be a mix between a 58 and 59. I could only see the "Z" standing proud, but after the frame came back from sand blasting, I can see 29 stamped next to the Z.
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
C TR2/3/3A Frame repair and value Triumph 2
J TR6 Repadding TR6 frame Triumph 0
B TR6 TR6 convertible top frame Triumph 0
zoohow BN4 Top Frame Installation Austin Healey 1
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
S TR2/3/3A Placing the differential on the frame Triumph 4
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
S TR2/3/3A Frame repair. Triumph 47
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
ActionJackson Spitfire Frame Triumph 0
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Frame repaired? Triumph 6
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
7 Wedge Removing sunroof frame Triumph 5
Rut TR4/4A 4a frame modification Triumph 6
D General TR Frame repair - recommendations for NJ area Triumph 3
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
D TR2/3/3A Windshield frame fitting. Triumph 2
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
JamesD BJ8 Top Frame Bumpers Austin Healey 12
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
Healey Nut Seat Base Frame Position Austin Healey 4
P TR6 TR6 Frame Stiffener Triumph 4
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
C 100/6 BN4 Soft Top Frame Austin Healey 16
B Bent frame rails near BE front end Spridgets 2
F TR2/3/3A Bumper frame brackets Triumph 10
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
F TR2/3/3A Bumper bracket to frame question Triumph 7
P For Sale MG TF Ash Frame parts for sale MG Classifieds 0
D BJ7 Hood frame mounting plate Austin Healey 7
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
dbenichou289 TR2/3/3A top frame bracket Triumph 7
J Painting a Frame and Substructure Austin Healey 12
W For Sale 1961 TR3a - Full Off Frame Restoration Triumph Classifieds 0
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
J Wanted Driver Seat Frame For a 1976 Triumph TR6 Triumph Classifieds 0
P BJ8 Frame Rust Options? Austin Healey 14
Rut TR6 TR6 frame Triumph 3
Got_All_4 TR6 Starting my frame restoration Triumph 32
M BJ8 Frame Dimensions Austin Healey 2
