TR2/3/3A TR 3A wheel cyllinders repair or replace
tomnanney
Finally figured out that the rear wheel cylinders are sticking some. They have been rebuilt by me, several times over the 26 years I've owned the TR 3. I'm wondering if I should send them off to be sleeved and rebuilt or just buy new ones. Anyone had good luck with any of the new wheel cylinders available? The new ones seem to be a less expensive option?
thanks
tom
TomMull
I've had no experience with the current reproduction wheel cylinders but I wonder about "sticking". The only problem I've had with mine was leaking. There are other things that stick, parking cable and hose from frame to diff housing for example. Perhaps these have already been checked? Tom
TR3driver
Great Pumpkin - R.I.P
That was my thought as well. When mine failed, I had no trouble bleeding and the rear brakes would release enough to drive the car, but still drag enough to get hot. For some odd reason, new cylinders didn't help :smile:
Another possibility, if you have the 10" brakes with support studs instead of hold-down springs, is that the studs are really badly out of adjustment and allowing the shoes to **** within the drum. I didn't notice mine dragging particularly, but there was this odd clunk every time I started off after using the brakes; which turned out to be the shoes falling back against the studs.
CJD
I rebuilt my wheel cylinders for years...till I checked the price of new. After that it was no contest. The new cylinders are just too cheap to mess with rebuilding the old, that are usually pitted anyway.
DornTRoriginal
I decided to purchase new cylinders for exactly the reasons stated; they are kinda inexpensive and quite important to have operating correctly. The problem I had was that I had to wait for a while until they were available from my supplier so I went ahead and assembled the hubs onto the car. I finally got the new cylinders however, now I am having a lot of trouble installing the spring and clips onto the back plate.
I've read the Buckeye Triumphs technical articles and reviewed other threads in the archives but I am really frustrated and I have managed to bend the spacer piece twice without getting everything correctly assembled. I'm starting to think the best solution is to take the hubs apart and assemble everything off the car, on the work bench? That means disassembly of the hub which I would like to avoid if I could.
Anyone have any suggestions, I know this is a topic that has had a fair amount of discussion in the past any worldly advise or suggestions.
TR3driver
That is one of the very few areas where the Buckeye articles are wrong. And the diagrams in practically every manual are wrong as well.
If you follow the words in the back of the TR3 Bentley, they should snap right in. I use a screwdriver for the final piece, tapping lightly on the handle, but the other two go in place with just fingers.
TexasKnucklehead
Mark Macy wrote an article in TRA national #112 on this, and I made sure to stuff it in one of my manuals in the brake section. Every time I do this, I have trouble. Trying to replicate what was previously done is usually, obviously, incorrect. I am always amazed at how something so simple to do, can be so complex if you do not know the exact procedure. -It's only a couple pieces, how could it be that difficult?
2long
Is the tr2 factory manual wrong on this point? If so, can someone summarize Macy's insight so I can annotate my manual? I wish I had a good list of any well known errors in that invaluable manual, so I could correct the few errors.
Dan
TR3driver
No, the TR2 manual isn't wrong, because it doesn't cover Girling brakes (found only on later TR3/A/B). But the diagram in the back of the TR3 version is wrong. To see the difference, compare the diagram with the text I posted above (click on the image to see a larger version).
Crankshaft
I used Randall's (Mr. Triumph) instructions two months ago and the assembly went flawlessly. I couldn't't believe how easy it went after struggling so many times
DornTRoriginal
I am not having much luck at all. What am I doing wrong? I think I followed the instructions correcty, when I try to put the retaining plate between the distance piece and the spring plate, the entire assembly of the spacer and the spring plate slides towards the handbrake lever. The retaining plate does not "tap into position", if I continue to try to get the retaining plate to "seat" the distance piece will bend and distort from the pressure. I can put the assembly together without the backplate but once I mount the wheel cylinder onto the backplate it is very, very tight and binds. I did have success putting the distance piece and the retaining piece in together, with the open ends facing towards the hand brake lever, it's snug but is not correct according to what I understand.
Are there any tricks to taking the assembly appart without damaging the distance piece? OMG this is a pain! My problem is the first picture at the top the second one is the "example" without the backplate.
T
tomnanney
I used Randall's (Mr. Triumph) instructions two months ago and the assembly went flawlessly. I couldn't't believe how easy it went after struggling so many times[/QUOT
Who is Randall or Mr. Triumph? can you post instructions or tell me where to find them.?
T TR6 Steering Wheel Lock Triumph 2
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
D Removing the steering wheel hub Spridgets 12
Todd78d Wire wheel cleaner Spridgets 1
zoohow wheel spacers Racing 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K 1068 mkIII wire wheel rub Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
K TR6 TR 6 Wheel Studs Triumph 10
AUSMHLY Front Wheel Spin Drag Austin Healey 6
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
Editor_Reid Wrapped Steering Wheel Austin Healey 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
kodpkd Leather Steering Wheel Cover Austin Healey 3
KVH General Tech Wheel Dollies Triumph 5
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
P 100/6 Front Wheel Alignment Austin Healey 10
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
prb51 BN6 Wheel/Tire Combo Austin Healey 26
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
LAW75 Derrington Steering Wheel Austin Healey 19
C Spitfire rear wheel bearing Triumph 2
W TR2/3/3A Wire Wheel Conversion Triumph 5
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
R Wire Wheel Fit Austin Healey 10
Donald1107 TR2/3/3A Wheel bearings Triumph 8
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S BN1 Wheel-Tyre Combination Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
drooartz What am I seeing - oil/grease on wheel Spridgets 20
A Austin A40 trafficator steering wheel Other British Cars 5
