I just discovered that when I installed the new slave cylinder, I mounted the black plate on the wrong side. After wasting the day correcting my mistake, I do have rod sitting where it should be.
New problem. When I tried to bleed the slave cylinder I have no fluid pressure from the clutch side of the master cylinder. The brake side is fine. It is a new MC?
When I pump the clutch it goes all the way to the floor; no resistance? When I try to bleed the slave cylinder, no fluid enters my bleed jar? No lines appear to be leaking?
Dick
Dick
