Trevor Jessie
Maybe another bit of bracing on the inside of the door opening. That A-pillar skin will flex quite a bit.
Trevor Jessie said:Maybe another bit of bracing on the inside of the door opening. That A-pillar skin will flex quite a bit.
racingenglishcars said:Phil, I don't know how tough the MOT can be, but here they take a pointed hammer to each and every thing that looks like it could be rusty, and if it makes a hole, it fails.
(But that's ok. On Opels they will fail it just on suspicion of rust)
You have som suspicious areas, but if the welds hold, it should be ok. If the welds burn the surrounding rust, you should have cut further.
It looks like you're on the right track.
tosoutherncars said:Well, it's the wrong marque, but here's my diary of floor & rocker replacement on my VW Rabbit.
Duncan's Rotisserie Rabbit Resto
Certainly gives you some ideas, as far as bracing, cutting out old panels, tack- and rosette-welding, etc.
Best,
Duncan, Ottawa
'78 Midget 1500 "Milo"
