TR6 Thumping noise
pdplot
Since installing the Goodpart spacers on the left rear spring, I've noticed a banging or thumping noise in the rear when traversing bumps - of which there are plenty around here. Any ideas?
Do you have lever or tube shocks? Either one will have rubber bushings that go thru the A-arm. Were they in good shape, and did you get them set right? Is the shock link ok if you have the lever shocks.
Tube shocks. Maybe tomorrow I'll pull a wheel and have a look if my (soon to be) 81 year-old back will let me...As my late father used to say, I can now do very well once what I once did very well.
Be sure to look at the frame in that area for any signs of cracking or splitting.
Pulled off both wheels. Almost gave myself a hernia lifting them back on, but I saw nothing amiss with the rear suspension or shocks. Bump stops looked like new (they are). I even checked the spare tire and toolkit - all tight and snug. Still making that noise even pulling out of my poorly maintained driveway. I'm stumped. It sounds like the sound is coming from the middle rear of the car - maybe the differential mounts? Why now when they never made noise before? Could lifting the left rear about 1 1/2" made the differential hit anything?
Maybe dry splines on the axle shafts, they might be binding.
Dry splines? When we installed the spacers, we dropped the stub axle. The splines looked fine. I don't know about the right side but it never made any noise before the spacers.I think I have to take the car down to my mechanic and put it up on a lift. I can't lay under a car any more. Worse than that, I got a bit light-headed after lifting those tires onto the wheels. I'm on blood pressure medication. Old Age is not for cowards...
Someone suggested the upper end of the shock hitting the body and someone else suggested loose swing arm bushings causing the bolt to rattle around. What think you of these suggestions? As an aside, I don't think too much of the Triumph IRS. If I was buying a TR4, I would avoid it.
I have an IRS and agree w/ u but anyway I've had 2 noises w/ stock shocks, first just a loosening connection from trailing arm to shock arm. Quick find. Second was shock itself, had maybe 1/8" play side to side on shaft coming out of the shock, didn't take much. It sounded like something was loose enough to make the entire rear end fall off and took a while to find. I was finally sure after taking it off and driving. Make you crazy, good luck.
Just had a thought. Could it be the driveshaft or u-joint hitting the frame or body? I once ran into this problem on an MG.
If it was something like that, something rotating, seems like there would be a lot of vibration.
I'm basing that on the memory I have of a drive shaft just before it 'came loose' completely.
Now that I think of it, Poolboy, you're right. The driveshaft is revolving and makes a **** of a racket when it hits anything. When I get it up on a lift I hope I can find the cause of the noise and will report back my findings.
Maybe jump up and down on it and have someone listen on both sides since it makes noise when it compresses. You did have one side apart which would be suspect.
