TR6 Thumping noise
pdplot
Since installing the Goodpart spacers on the left rear spring, I've noticed a banging or thumping noise in the rear when traversing bumps - of which there are plenty around here. Any ideas?
mallard
Do you have lever or tube shocks? Either one will have rubber bushings that go thru the A-arm. Were they in good shape, and did you get them set right? Is the shock link ok if you have the lever shocks.
P
pdplot
Tube shocks. Maybe tomorrow I'll pull a wheel and have a look if my (soon to be) 81 year-old back will let me...As my late father used to say, I can now do very well once what I once did very well.
poolboy
Be sure to look at the frame in that area for any signs of cracking or splitting.
P
pdplot
Pulled off both wheels. Almost gave myself a hernia lifting them back on, but I saw nothing amiss with the rear suspension or shocks. Bump stops looked like new (they are). I even checked the spare tire and toolkit - all tight and snug. Still making that noise even pulling out of my poorly maintained driveway. I'm stumped. It sounds like the sound is coming from the middle rear of the car - maybe the differential mounts? Why now when they never made noise before? Could lifting the left rear about 1 1/2" made the differential hit anything?
mallard
Maybe dry splines on the axle shafts, they might be binding.
P
pdplot
Dry splines? When we installed the spacers, we dropped the stub axle. The splines looked fine. I don't know about the right side but it never made any noise before the spacers.I think I have to take the car down to my mechanic and put it up on a lift. I can't lay under a car any more. Worse than that, I got a bit light-headed after lifting those tires onto the wheels. I'm on blood pressure medication. Old Age is not for cowards...
P
pdplot
Someone suggested the upper end of the shock hitting the body and someone else suggested loose swing arm bushings causing the bolt to rattle around. What think you of these suggestions? As an aside, I don't think too much of the Triumph IRS. If I was buying a TR4, I would avoid it.
sail
I have an IRS and agree w/ u but anyway I've had 2 noises w/ stock shocks, first just a loosening connection from trailing arm to shock arm. Quick find. Second was shock itself, had maybe 1/8" play side to side on shaft coming out of the shock, didn't take much. It sounded like something was loose enough to make the entire rear end fall off and took a while to find. I was finally sure after taking it off and driving. Make you crazy, good luck.
P
pdplot
Just had a thought. Could it be the driveshaft or u-joint hitting the frame or body? I once ran into this problem on an MG.
poolboy
If it was something like that, something rotating, seems like there would be a lot of vibration.
I'm basing that on the memory I have of a drive shaft just before it 'came loose' completely.
P
pdplot
Now that I think of it, Poolboy, you're right. The driveshaft is revolving and makes a **** of a racket when it hits anything. When I get it up on a lift I hope I can find the cause of the noise and will report back my findings.
sail
Maybe jump up and down on it and have someone listen on both sides since it makes noise when it compresses. You did have one side apart which would be suspect.
kennypinkerton My Alfa - I figured out that thumping Other Cars 27
A Why is my car making this noise? Other Cars 5
Popeye TR4/4A Transmission noise - intermittent Triumph 22
AUSMHLY Transmission Noise Austin Healey 11
Gliderman8 TR6 Lever shock noise Triumph 18
LAW75 High-Pitched Noise Austin Healey 13
B High-Torque Starter Rattling Noise Austin Healey 3
nicko Strange Engine Noise Austin Healey 7
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
Martinld123 Steering Idler Noise Austin Healey 21
S TR2/3/3A Noise from clutch area? Triumph 20
P TR6 Clutch pedal click noise Triumph 2
I T-Series air cleaner/ noise suppressor MG 1
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
P TR6 Clutch pedal noise Triumph 2
P TR6 Clunking noise in rear continuing Triumph 39
R Clutch Throwout Bearing Noise? Austin Healey 2
Gliderman8 TR6 What's that knocking noise? Triumph 6
Kleykamp TR2/3/3A Engine noise Triumph 4
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
F TR2/3/3A Strange Loud Noise Triumph 11
Michael Oritt Clutch-related noise Austin Healey 14
B An expensive sounding noise possibly the transmission Austin Healey 7
M TR2/3/3A Annoying Vibrating noise?? Triumph 11
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
G Tappet Noise Austin Healey 8
TulsaFred Generator or water pump noise? Spridgets 20
S Disconcerting engine noise, please help if you can. Austin Healey 56
2billydavies TR2/3/3A rattling noise on TR3a Triumph 12
J MGB Project car done; front end clunk noise while braking MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
RAC68 Loud Trans Scrapping Noise Austin Healey 9
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
K TR2/3/3A Gearbox noise.... Triumph 8
P TR6 Rear suspension noise Triumph 3
D Ticking noise when driving Austin Healey 8
bugedd Rear end noise [insert joke] Spridgets 11
Lukens TR2/3/3A Cog v-belt causing noise. Triumph 8
P TR6 Clunking noise in rear Triumph 2
busybrit MGB Slight starter motor noise MG 5
N BJ8 Noise when going from reverse to forward Austin Healey 2
J Funny noise in my mini British Motor Corp 12
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
Lutz Kramer Noise from the engine compartment Austin Healey 21
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
N TR6 Diagnose noise from clutch area Triumph 13
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
