T-Series TD Door Hinges: just what is the difference between right and left?
parkerstudio
Hi Folks:
A newbie here. I would like to know just what the difference between the right and left door hinges on the MG TD is? Are they the same castings and the hinge pins are just put in from different sides, or are their shapes more complicated than that? Has anyone ever compared sets right and left? The reason I'm asking is because I'm rebuilding a basket case TD, which only has its driver's side, or left hinges and I'm looking for a pair of rights. When shopping for rights, I won't be able to tell rights from lefts otherwise. Thanks in advance!
Grantura_MKI
Welcome,
if you are doing coach work, purchase a new set. It is a critical that the door and timbers are right.
Best to start with new.
PAUL161
The top and bottom hinges are different! Bottom hinges has two screw holes, top has three. Right and left is determined by which way the pin is installed. PJ
PAUL161
I forgot to ad, the doors on a T series MG are the toughest item on the car to get right. As was suggested before, do your self a favor and start with new hinges. Not cheap, but being made of brass, old ones get distorted very easily after 60 years. To get the doors to close properly, shimming of the body in various places is a must and the shim points will vary in thickness. The latches are another story getting them to latch fully in the hole. I don't envy you on that point. The fun is just beginning. PJ
pdplot
The TC/TD door latches were possibly the worst latches ever fitted to a car. They loosen, hang down, refuse to latch, pop open, etc. I ought to know. I've owned 3 TDs, one restored by me in 1974. I clearly remember a race at Brynfan tydden in Pennsylvania back in the late '50s where the driver door unlatched on a TC during the race and the suicide door blew open. The TC was being driven by an old friend and high school classmate of mine.
Grantura_MKI
I do not have any problem with the latches. They were fitted to a number of vehicles back in the day....AC Bristol's and Cobras to name a few.
problem usually is old timbers, over drilled/stripped holes, etc.
PAUL161
With all that knowledge, I'm kinda surprised you didn't know about the hinges. PJ
Grantura_MKI
No need to spill all the info. Was sterling the OP to the correct solution. I have done more T series cars than I would like to count. Just finished building the coach work for a Riley Gamecock.
Is that enough for you?
vixen-mk2
If The original poster is looking for good advice i would do exactly what Grantura_mk1 suggests every time i have not taken his advice i have come unstuck Sound advice from someone who knows
Andrew
beachbumbarry
The drivers door on my 51 TD came open on the freeway at 60 mph. It broke the bar that stops the door from opening to far and the door hit my back fender and tire, leaving a black mark on the door.I here that some people install a strap that won't let the door open but about 2".
PAUL161
One more comment, if the doors are set properly and fit snug, the latches are fine if, when the doors are closed, the latch pin drops fully in the striker plate hole, leaving no play on the inside latch lever. If the latch and striker plates are as they should be, you can push the door closed and hear the latch snap the pin in the hole, the doors should never open accidentally. I can close my doors just by pushing on them and hear the latches slam all the way home. Took some time to get them that way, but well worth the effort. PJ
pdplot
On my 2nd TD - a '52 Mark II - a PO had drilled holes clean through the body and installed long bolts and nuts to hold the latch in place. No more problems. That MK II had an engine-turned aluminum dash panel over the wood. Looked great but you'd get blinded by the sun at certain angles. Not a great idea. It had also been "supertuned" by a PO who had installed an enormous Ford Holley carburetor getting 16 mpg. I took it off and replaced it with 1 1/2" SUs. Only owned it for 6 months - traded it in on a new TR3. But that's a story for another day.
Donald1107 TR2/3/3A Door hinges Triumph 14
B BJ8 door hinges Austin Healey 7
B Wanted BJ8 door hinges Austin Healey Classifieds 2
BoyRacer Sloppy 100-6, 3000 door hinges Austin Healey 4
tomshobby General TR making it easy to lube door hinges Triumph 0
B BJ8 Door hinges Austin Healey 16
bugedd Door Hinges Spridgets 1
A Freeing up Door Hinges Austin Healey 7
bugedd Frozen door hinges Spridgets 10
Superwrench BT-7 Door Hinges Austin Healey 3
G *&$%@+ Door Hinges !!! MG 29
R BN-1 door hinges Austin Healey 4
G Driver's door hinges. MG 2
chrpark surplus door hinges wanted Spridgets 2
chrpark Mk II Sprite/Mk I Midget Door hinges Spridgets 1
hondo402000 TR6 TR 6 Door hinges Triumph 4
W Spare door hinges Spridgets 9
F Xk 120 OTS door hinges Jaguar 3
N TR6 TR6 Door hinges Triumph 1
P Replacing door hinges and paint British Motor Corp 4
timbn2 Metal AND Brass door hinges...huh????? Austin Healey 5
C Door hinges - steel or aluminum? Austin Healey 9
jlaird Todays tip - Door hinges Spridgets 8
H TR2/3/3A TR3 Door hinges Triumph 2
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
