jcatnite
I broke the (for lack of a better term) pedestal bolt that holds the intake and exhaust manifold on my 1500 tonight. I knew it was toast as soon as I put the wrench on it. It seems to be a stud that has a spacer welded in the middle. Moss and VB don't show a replacement. Any other 1500 owners ran into this? I might just turn a nut down to the proper thickness and use a new stud. Also, I broke the EGR valve off the exhaust manifold. Of course the pipe is still in the manifold. I thought about trying to drill it carefully and then pick the remainder out of the thread. I had been using heating and PB blaster treatment on it for about a week before I got the courage to put a pipe wrench on it. Does anyone know if I can weld that port up? I got the feeling that the exhaust manifold is cast and I've never had much luck welding that. Just canvasing for suggestions.
JC
JC
