TR2/3/3A Starting Conundrum
Goose55
My TR2 is stumping me again so I was hoping that perhaps someone can give me some ideas of what the problem could be. Basically she refuses to start. She has a charged battery, spark at the plugs, and there's fuel in the carb bowls. She does fire up when I spray Quickstart into the carb throats but she then coughs and dies once the vapour is used up. Also, I noticed that after she starts briefly with the Quickstart, there’s some wisps of smoke that emerges from the oil filler top. The smoke isn’t hot so maybe it's vaporisation of the Quickstart or the fuel additive(?). Any ideas would be welcomed.
Question: if you try to start the engine without using the Quickstart, do the plugs get wet with gasoline?
Tom M.
Thanks for the quick response. I've cranked her over a few times and her plugs stay dry.
ah-HAH! So no fuel is reaching the cylinder. Do you see fuel in the glass fuel pump bowl?
I see you had quite a bit of work done on the car back in 2018. https://www.britishcarforum.com/community/threads/help-what-have-i-bought.106666/page-3
Hi all,
There seemed to be quite a bit of interest in this car a couple of years ago so I figured that I would give you an update. The potential buyer (who made the original post) didn't buy the car in the end but I thought that it had good restoration potential so I bought it instead. Anyway, from local records I've found that she's a TR2 built in Durban, South Africa in August 1955 (hence the chassis # TR751, Engine # TS7514E, commission # TS7188). Since purchasing the car, I spent quite a bit of time removing and replacing the various TR4 parts along with many other little jobs before handing her over to Bill at CCC for reconditioning of the engine, restoration of the front and rear suspension, installation of the front inner wings, installation of a new wiring loom, replacement of the rusted sills and rear fender bottoms and many other items that required attention. She's no show queen (yet) but she's now at a stage where I can happily drive her for another year before sanding down the body, doing a respray, and redoing the interior (I'm doing a body-on restoration due to limited funds, garage space, and time). It seems that I can't upload any photos but I'll try again as she progresses.
When was the last time the engine actually ran properly?
Good fuel wouldn't go bad in a few months. Dodgy maybe, but that wouldn't prevent it from even firing.
If fuel is going to the carb fuel bowls, but no fuel is reaching the cylinders, seems the problem is the carb itself. Plugged jets maybe, or something plugging the intake manifold? Car fires with Quickstart, so it's got spark.
If you have the air cleaners off, look inside the throat of the carbs and you should see the needls going down into the jets. Pull the choke and make sure the jets are acutally moving up/down, and that there is a little weep of fuel at the jet. The floats should keep the fuel level in the bowl just at the level of the top of the jet.
Try cranking the engine with a hand over each carb and make sure you're getting good vacuum through the carbs/manifold when the engine is turning over.
Also, check to make sure the fuel tap on the lower left front inner wing isn't closed. There may be fuel in the filter bowl and carb bowls, but no fuel pressure due to no fuel getting to the pump. I've seen that little vavle stump more than one person when it's sneaky-closed.
I'm thinking that if his engine was running fine until parked a few months ago, the fuel tap and vacuum access shouldn't have changed. But it's a good thing to check all possibilities.
My TR6 had issues with nasty rich mixture and poor starting when I first got it. I bought a hot rod style, after-market coil and put in it. No more starting problems. Check the spark. Mine was weak & yellow, even on a charged battery. ...J.D.
