TR2/3/3A Stanchion Guide
sp53
When there is no way to get vise grips on the backside of the caged nut or with a windshield I think they are welded nut with no access, you are better off to drill the head off the screw and re-tap the hole. Maybe some light tapping with an impact hammer, but you do not want to spin the nut in the cage or knock the nut off.
steve
CJD
Standard practice in removing Triumph bolts...
1)Wrench/screw driver
2)Impact wrench/hammer driver
3)Repeat with heat
4) Vice grips
By this point the head has broken off.
5)Drill with left hand drill bit and extractor
6)Drill completely out
7)Re-tap/replace nut
I am being completely honest when I tell you I have drilled out as many bolts on my car as I have unscrewed. Of course, now that it is restored that will not happen again.
JHaydon
+1 to penetrating oil! And if you can see (by contortions and/or a mirror and flashlight) rust, try knocking some of it off with a wire brush. Trying to drag that stuff through the nut will grind away at the female threads.
Also +1 to impact screwdrivers. The day before I got mine I didn't know they existed. The day after I got it I didn't know how I existed without one.
sp53
One added help for stuck caged nuts on a restoration is to take a hand carry able sandblaster pot and just blast all the rust and stuff---- out and off the nut. Then put power blaster on the freshly blasted nut and that soak.
steve
charleyf
The nuts behind the stantion supports are welded in place on my 59 TR3A. They are not caged nuts.
I had a couple that I had to drill out. I then had to refill the holes with a MIG welder and tap in the new threads.
Charley
T TR2/3/3A Windscreen Stanchion Guide Plates Triumph 7
MGTF1250Dave TR2/3/3A TR3 Windscreen Stanchion Guide Plate Triumph 11
D TR2/3/3A TR3 post 60000 windshield stanchion guide plates Triumph 5
bmurphy7369 TR2/3/3A TR3 Windshield Stanchion Guide Plates? Triumph 22
J For Sale Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
R TR2/3/3A Windscreen stanchion Dzus problem Triumph 13
Tinkerman TR2/3/3A Windscreen stanchion mounting question Triumph 3
T Windshield Stanchion and "plate" on TS60001 and later Triumph 5
A Winshield, Stanchion to frame assembly. Triumph 4
T TR2/3/3A TR3B stanchion to frame scew size Triumph 8
luke44 TR2/3/3A TR3 Windshield Stanchion Short Screws Long Screws Triumph 2
K TR2/3/3A TR3A Windshield Stanchion Screw Removal? Triumph 8
CJD TR2/3/3A TR3 Windscreen Stanchion Swap? Triumph 9
mrv8q TR2/3/3A TR3 Windshield Stanchion Q Triumph 6
timbn2 stanchion repair , can it be done? Austin Healey 10
P Windshield Stanchion Seal Triumph 4
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
S Wanted: AH Concours Registry Guide Austin Healey 2
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
BigGreen For Sale Anderson / Moment Restoration Guide for sale Austin Healey Classifieds 0
Basil MGB Buyers Guide MG 0
F Restoration Guide Austin Healey 2
Michael Oritt Anderson/Moment Restoration Guide for sale Austin Healey 8
J TR2/3/3A Manganese Bronze Valve Guide Clearance Triumph 14
J Wanted TR3 Windscreen guide plates Triumph Classifieds 7
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
Zitch TR4/4A Window Guide Writeup Triumph 2
dougie Silodrome - Big Healey Buyer's Guide Austin Healey 4
Nunyas MGB Hagerty's MGB Buyer's Guide MG 0
D Another Valve Guide Question Austin Healey 1
K TR2/3/3A Windshield stanchions on a TR3b - guide plates?? Triumph 13
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
Sarastro T-Series MG TD Valve Guide Replacement MG 8
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
T TR2/3/3A Cyclinder Head work and valve guide issue Triumph 2
JFeher TR2/3/3A Installing valve guide seals on 59 TR3 Triumph 6
TulsaFred Bonnet Install [without guide marks] Spridgets 10
S eBook Version of Anderson/Moment Restoration Guide Available Austin Healey 21
H Austin-Healey 100, 100-6, 3000 Restoration Guide Austin Healey 14
PatGalvin TR5/TR250 TR-250 Buyers Guide Triumph 12
R Moment restoration guide Austin Healey 2
H restoration guide book Austin Healey 10
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
BN6_2197 Copy of Austin Healey Restauration Guide Austin Healey 9
S Austin healey Guide to Historic Colors Austin Healey 3
