JimLaney
15 years ago my MK III was undergoing rebuild. The build stopped and no fluids were ever added. I bought it recently and have started over. Yesterday I removed the pedals and the master cylinder for a re-do... cleaned up outside, removed push rods, pins, and exterior boots. The interior plunger, spring, sup will not budge. It sits soaking in DOT 4 but I'm not optimistic that they will come out. Any trick or is it a replacement issue?
If replacement, should I go with update to independent reservoirs for clutch and brakes or replace as is...?
I
I
Hi Guest!
