Don_R
Andrew,
Can't answer that. They were installed prior to my caretaking. Apparently, one of the POs knew of the problem as 3 of the 4 wheels had cut down studs. When I removed the wheel I showed you there were clean rub marks on the rim and the inner portion of the hub showed rust like the rim wasn't fully seated.
Gotta go. packing for drill. Gong to Ft Indinatown Gap for rifle Qual be back Sun.
