I know it's part of the charm, but when I finish my (final) MGA restoration, I will probably give it to my daughter, who might not appreciate the typical oil leaks. Has anyone found a good solution to the chronic rear main leaks on these engines?
I know of no conversion set to make it possible to use a "lip seal" in the scroll seal engines. Some folks have made one-off back plates but it's pricey to do. Best R.O.I. is to buy her a long aluminum cookie baking tin. :smirk:
Bob, there is a conversion using a seal from, I think, a Chevy engine, I'm not sure of the proper procedure, but it is a little pricey as it should be done by a machine shop. The conversion kit costs around $250.00, the cost to have it installed depends on the machine shop rates. It does work, but pricey. PJ
Here's a picture of the conversion. As you can see, it's not a quick job.
PJ it looks like the seal lip would ride not on the scroll but on the flywheel flange. Just from the picture , as that's a much larger diameter than the scroll if that black double lipped thing is the seal that is.
Kevin
You know what, I think your right. Remembering when I put a new seal in my 93 Chevy truck with a 350 in it, it appears to be almost identical, on the outer flange.
