M_Pied_Lourd
Now if I could only try to figure out how to use this welder
Practice makes perfect
Cheers
Tush
Any tips on how to properly check the frame for damage would be greatly appreciated.I set my frame on saw horses, got it level then dropped a plumb to the floor at all the datum locations noted in the Service Instruction book. Marked the floor and checked the diagonals. The Frame unit in the Service Instruction book has a very detailed description on checking the frame.
David
David
Hello JP
Here is a link.
https://tecb.eu/onewebmedia/Triumph TR2, TR3, TR3A factory service manual.pdf
Yep, I've taken a bit of skin off now and again with the grinder....gotta be more careful!
I've finally got the garage door open wide for the first time in about 4 months...weather is getting warmer and is staying above 0 C overnight. Certainly does lift my spirits.
Look after yourself! I look forward to some inspirational updates from you!
Cheers
Tush
