TR2/3/3A Sliding yoke
Agrandshort
Agrandshort
So after I got this yoke cleaned up. I unscrewed the dust cap and tried to pull off the "sliding" yoke. It did not. Found that it had a set screw holding it on. Is this suppose to be a set screw or a greaseable zerk?
There should be a grease fitting on the yoke. If it is not visible elsewhere on the yoke, then your circle is where it apparently broke off.
Sorry it has taken so long to get this posted but maybe it will help. Yes there should be a grease fitting on the yoke. Frank
Funny story...
The first time I disassembled a slip joint I didn't know the seal was there. I just pulled the 2 apart by the hardest. When it came time to put it back together, the old seal had perfect teeth cut into it, and I thought that is how it was supposed to look. I even spent a couple hours in CAD programming to cut a new cork seal with the same perfect teeth marks. Of course I later found out that the seal only had the teeth because I screwed up removing the yoke!! It only takes 2 minutes to program the cutter for a round seal, LOL.
Do not dream for a minute that the factory did everything to spec. All I am saying is
it is good to know for sure. "Done right, done once" as it has been said.
Merry Christmas Crusty
Mad dog
You will likely be good just putting it back, especially if you kept the yoke in the same orientation. If you end up with a high frequency vibration, then you can always pull it back out to be balanced. I have always sent them to a driveline shop...which is getting hard to find these days.
After some consideration, I decided I better get it balanced before returning it to the car. Thank you all for the recommendations.
