My Side screens have arrived and they look great.
How far into the gap between the windscreen stanchion and the SS plate should the side screen lip go? I think I may be too far forward on the drivers side as the bottom of the lip wants to curl out side the stanchion also a little low. Should the metal frame of the side screen be level with the top of the stanchion?
David
There are so many things that have to fit exactly to get the front edge and the top to fit repeatedly.
As I plan to not get out in the rain like you would in a daily driver I think I will concentrate on getting the front edge to work every time.
I would do the wiring first as some goes under the carpet. Looking at a TR4 a friend has I noticed pieces of plastic tube over the "T" shaped wire straps that are welded to the body. I can see that would prevent possible chafing of the wires.
David
