TR2/3/3A Sending out SU's for throttle shaft rebushing........
sp53
Karl--- steveg suggest Tom Bryant did work and I believe Tom Bryant posted a couple posts on the thread SU running rich; the thread I posted and you were there too - these guys know plenty, I can tell by the way they communicate Plus it looks like Tom Bryant re-bushes Carbs. I would definably look into that!
steve
steveg
mctriumph
Why would you do this when there is a great DIY fix. The wear on the shafts can be repaired
with metal bonding epoxy and sanded back to proper fit. With synthetic grease lasts for decades
MD
K
karls59tr
Bronze
MD
Sounds good.Where can I find out more about that process? How could you sand the shaft to a consistent roundness?
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
B General MG 77 MIDGET Gas tank sending unit MG 1
BoyRacer Fuel Tank Sending Unit Austin Healey 3
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
Joe Schlosser Bug Eye fuel gage sending unit Spridgets 15
S TR2/3/3A gauge sending unit Triumph 2
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
D TR6 Oil sending light Triumph 10
TulsaFred Fuel Sending Unit Spridgets 4
George Zeck Sending Unit is toast ...... Spridgets 4
rjc157 fuel tank sending unit Austin Healey 4
R Fuel sending unit Austin Healey 4
V Fuel Gauge Sending Unit Austin Healey 3
B Sending Unit Adjustment? Spridgets 11
C TR2/3/3A fuel sending unit Triumph 9
D TR6 Oil sending switch Triumph 5
6 Fuel gauge, sending unit, and tank compatibility Spridgets 9
D TR6 Sending Unit Triumph 1
PAUL161 MGB Replaced sending gas gauge unit. MG 5
B Temp sending unit removal Austin Healey 4
B Gas Tank Sending Unit Orientation Austin Healey 4
mgedit Buying Parts from Moss UK and Sending to US Triumph 12
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
1 MGB Need to replace a sending unit MG 14
pkmh BJ8 Fuel Tank Sending Unit - Ground Wire Austin Healey 8
H TR4/4A TR4 Gasoline Sending Unit Triumph 5
R TR2/3/3A TR3A Fuel sending unit Triumph 3
bugedd Fuel tank sending unit Spridgets 18
E BE Fuel Sending Unit Wire Spridgets 0
stretchit2 Fuel Sending Unit - Short? Austin Healey 16
M Tell me I need a fuel tank sending unit Spridgets 21
Lynn Kirkpatrick Oil Pressure with the Sending Unit MG 4
AUSMHLY fuel sending unit float position Austin Healey 16
bugedd Fuel Sending unit Question Spridgets 6
G Fuel Gauge - Sending Unit Question Austin Healey 20
I TR6 TR6 oil sending unit thread size help please? Triumph 12
S TR2/3/3A tr3 sending unit gaskets Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
M Smiths Fuel Tank Sending Unit Austin Healey 3
W Reminder about testing sending units Spridgets 8
Lynn Kirkpatrick Oil pressure gage or sending unit? MG 1
johnrip Wedge TR7 temperature sending unit and cooling Triumph 5
