RAC68
I am amazed at the creativity in this discussion. From harmonic frequency to single piece dash have been though proposed and yet over the more than 50 years this condition has been present, no definitive solution has been accepted.
Is there a definitive definition of “Scuttle Shake”? If so, what is it?
As Rich indicates, he and many others have found that this condition has responded positively to rear drum balancing and some have indicated that dog house reinforcement has cured the problem for them. Yet, others have countered that performing these solutions has not solved the problem for them and presented additional ideas.
Steve Hall has indicated he is on a journey to a solution and I must agree. Over the years our Healeys have existed with this condition, many have modified, repaired, and replaced many structural components of their Healey's original 15-gauge construction and have often noted deterioration (rusting) from the inside of their frame's thin sheet metal box sections. Since these changes would change the original structural integrity of the Healey’s substructure and the level of rigidity they impart, it seems odd that the range of what we are identifying as scuttle shake can still be identified as happening within a defined speed rang (50 MPH and 65 MPH).
Since I don’t believe the lack of a single-piece dash has much to do with this condition and the harmonic frequency of the substructure would definitely have changed with the progression of rust or modification/repair, what are the reasonably potential causes of this condition and how do we validate them.
1. Rear Drum Imbalance (possibly complicated by improper wheel balance/tune) could be a cause but only if those who have implemented rear disks do not experience the same shake.
2. Vibration from imbalanced drive shaft or fly wheel could be the cause but only if not experienced by those who installed Toyota 5 speeds.
3. etc.
So, what can we definitively rule in with the least amount of speculation and how can we validate.
Ray 64BJ8P1)
3. etc.
Ray 64BJ8P1)
