Jim_Gruber
Supposed to be -18 Monday morning before wind chill in Dayton. I feel like I'm back in Milwaukee.
.......If your wife worries about it, then start explaining how much safer an autolift would be.Worked for me!
While you are at it and have the car on a lift consider adding what is essentially a skid plate right at the point where that exhaust pipe is at it's lowest point. Someone, possibly Bud Osbourne? Posted pics on another forum for welding a heavy piece of steel to the chassis rail / edge of the opening where the exhaust pipe goes through the body. The lowest point of contact with the ground becomes this point rather than the exhaust pipe. A simple solution which would not cost much to fabricate but access to the underside of the car to fabricate would be required. Could whoever posted those pics do so again with possibly some dimensions. I think this is a setup many of us could use. I for one will be adding to Bugsy II when he goes upside down in the next few months.
